你好,
只要我们已经有了产品的头…该产品有CyPress CY7C68013A(USB控制器),并在Windows上工作。我们正计划增加对Linux发行版的支持。 关于这个要求的几个问题: 1)我们有没有支持从柏树建立Linux端的USB固件? 2)在Linux主机上测试固件的工具是什么? 3)我们有什么例子能给出相同的想法吗? 4)关于CY7C68013A系列芯片的Linux驱动程序,比如我们有Windows(CyUSB,LIB/DLL)的驱动程序? 5)在Linux中开始执行代码的任何支持文档? 谢谢 SJ 以上来自于百度翻译 以下为原文 Hello, Just a heads up on the product we already have..The product has a cypress CY7C68013A (USB controller) and is working on windows. We are planning to add support for the linux distrubutions also. Few questions regarding this requirement: 1) Do we have any support for building the USB Firmware on linux side from Cypress? 2) What about the tools to test the firmware on linux host? 3) Do we have any example projects to give an idea about the same? 4) What about the linux drivers for CY7C68013A series of chips like the one we have for windows( cyu***.lib/dll)? 5) Any supporting documents to start compling code in linux? Thanks SJ |
3个回答
你找到解决这个问题的方法了吗??
我也有同样的问题,我怎么能像“NX2LP NAND编程实用程序”一样闪亮Linux的NAND控制器?? 以上来自于百度翻译 以下为原文 Did you find solution for this problem ?? I've the same problem, how can I preflashing the NAND controller for linux like the "NX2LP NAND Programming Utility" ?? |
您可以用SDCC构建固件,虽然我不相信它与Keil兼容。
也有HTTP//SurfFur.NET/PrimeSt/Fx2Lb/Dead,它有各种各样的帮助例程。 您可以使用LIUBBB向您的设备发送命令——我使用它以及Python绑定来进行测试。 以上来自于百度翻译 以下为原文 You can build firmware with SDCC, although I don't believe it is source compatible with Keil. There is also http://sourceforge.net/projects/fx2lib/develop which has helper routines for various things. You can use libu*** to send commands to your device - I use it as well as the python bindings for testing. |
对于这个线程来说,这已经很晚了,但是这个家伙将Keil编译器的一些样本移植到SDCC和Linux:www. DaielCelMeun.com /PrasaPi/ index .En.html
我们没有KEIL编译器的资金,所以我在Windows中使用SDCC。我的固件是基于他的代码,它主要工作。还有一个错误… 比尔 以上来自于百度翻译 以下为原文 This is late for this thread, but this guy ported some of the samples for the Keil compiler to SDCC and Linux: www.danielclemente.com/placa_pi/index.en.html#toc18 We don't have the funds for the Keil compiler so I'm working with SDCC in Windows. My firmware is based on his code and it is mostly working. Still one bug... Bill |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
571浏览 2评论
424浏览 2评论
437浏览 2评论
384浏览 2评论
916浏览 2评论
GMT+8, 2024-12-24 11:11 , Processed in 0.834152 second(s), Total 52, Slave 46 queries .
