你好:
我是一个购买的帐户,所以我的许可证应该允许访问所有内容。 但是当我使用System Generator for DSP时,系统说我的SysGen签出许可证失败了。 有人知道怎么解决吗? 谢谢 ! -------------------------------------------------- -------------------------------------------------- ---------------------- 错误:System Generator for DSP(SysGen)的许可证签出失败。 无法联系Xilinx许可证管理器。 请检查以下内容:(1)XILINX环境变量指向有效的ISE安装(2)$ XILINX / lib / lin64在LD_LIBRARY_PATH环境变量上报告:未指定 -------------------------------------------------- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi: I'm a purchased account, so my license should allow access everything. But when I was using the System Generator for DSP, the system said my license for SysGen checked out failed. Can somebody know how to solve it ? Thanks ! -------------------------------------------------------------------------------------------------------------------------- ERROR: A license checkout has failed for System Generator for DSP (SysGen). Failed to contact the Xilinx license manager. Please check the following: (1) The XILINX environment variable points to a valid ISE installation (2) $XILINX/lib/lin64 is on the LD_LIBRARY_PATH environment variable Reported by: Unspecified -------------------------------------------------------------------------------------------------------------------------- |
目前尚不清楚“购买的帐户”的含义。
如果您的公司购买了System Generator的许可证,您应该已经收到了该软件的许可证,它应该在许可证文件中。 您是否使用Xilinx许可证配置管理器验证您的许可证信息是否正确? ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 It isn't clear what you mean by a "purchased account". If your company has purchased licenses for System Generator you should have received a license for the software and it should be in the license file. Have you used the Xilinx License Configuration Manager to verify that your license information is correct? ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
632浏览 1评论
1684浏览 1评论
444浏览 1评论
201浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 16:20 , Processed in 0.945386 second(s), Total 46, Slave 40 queries .
