当使用PSoC3的Bootloader时,是否有PSoCCreator在PC端运行的任何工具?演示项目是如何通过I2C实现Bootloader的吗?非常感谢,乔治
以上来自于百度翻译 以下为原文 When using bootloader of PSoC3, is there any tool provided by PSoCCreator which is running on PC side? and is there demo project show how bootloader could be implemented via I2C? Thanks a lot, George |
7个回答
是的,乔治,我们有一个Bootloader主机应用程序,可以在PSoC创建者文件夹中找到。对我来说,它是在C:程序文件 CyPress PSoC创建者 1 PSoC创建者 bin BooLoad Engulo.xEX.EXE。PSOC3 I2C引导加载程序应用笔记将在几天内在网站上获得。问候,安努
以上来自于百度翻译 以下为原文 Yes George , we have a Bootloader host application which can be found in the PsoC creator Folder. For me it is in C:Program FilescypressPSoC Creator1.0PSoC Creatorbin bootloader_host.exe. The PSoC3 I2C bootloader Application note will be available in the website in a few days. Regards, Anu |
附上APP注释的草稿版本供参考。这将指导您如何使用I2C引导加载程序。问候,安努
以上来自于百度翻译 以下为原文 Attached the draft version of the App note for your reference . This will guide you how to use the I2C bootloader. Regards, Anu |
嗨,安努,非常感谢你的回答!我已经阅读了你的应用笔记,你说:“有可能让你的定制Bootloader项目包含其他通信组件安装用于其他目的”。如何制作基于UART通信的Bootloader?目前,如果UART组件放置,你不能选择它的标签。cydwr;>;“系统”>;“引导”——>;“IO组件”,它是空白的。最好的问候,乔治
以上来自于百度翻译 以下为原文 Hi, Anu, Thank you so much for your answer! I have read your application notes, you said "It is possible to have your customized bootloader project containing other communication components installed for other purposes". How to make a UART communication based bootloader? Currently, if UART component is placed, you can not choose it from the tab .cydwr;>"system"->"bootloader"->"IO component", it is blank. Best Regards, George |
乔治,此时引导引导程序只支持I2C。ANU的意思是,您可以将UART放到BootloadDeject中,而不是Bootloader以外的其他应用程序。安努,申请说明很好。我成功地创建了一个引导加载程序,并在15分钟内运行它。PSoC3引导加载程序真的很酷。
以上来自于百度翻译 以下为原文 George, The bootloader only supports I2C at this time. What Anu meant is that you can place an UART in your bootloadable project for other applications other than bootloader. Anu, The application note is very good. I was able to successfully create a bootloader and run it under 15 minutes. PSoC3 bootloader is really cool. |
嗨,Ganesh,明白了!这里是个不错的地方!非常感谢,乔治
以上来自于百度翻译 以下为原文 Hi, Ganesh, Got it! Here is a quite nice place! Thanks a lot, George |
对于PSoC 3的USB引导加载程序是否有类似的应用说明。
谢谢 文森特 以上来自于百度翻译 以下为原文 Is there a similar application note for USB bootloader for PSoC 3. Thanks Vincent |
嗨,文森特,
有一个示例项目,说明使用USB全速组件的引导加载程序。 下面给出了这个示例项目的链接: HTTP://www. CyPress?COM/?RID=46717 当做, DASG 以上来自于百度翻译 以下为原文 Hi Vincent, There is an Example Project which illustrates the Bootloader using USB Full Speed Component. The link to this Example Project is given below: http://www.cypress.com/?rID=46717 Regards, dasg |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3068 浏览 0 评论
2285 浏览 1 评论
2012 浏览 1 评论
3855 浏览 1 评论
1912 浏览 6 评论
3717浏览 2评论
2241浏览 2评论
575浏览 2评论
552浏览 2评论
3982浏览 2评论
GMT+8, 2025-7-4 14:06 , Processed in 1.325715 second(s), Total 89, Slave 73 queries .
