扫一扫,分享给好友
如果你下载CY8CITK-01软件(www. CyPress,com /GO/CY8CITK-1001),它会把工具包安装到PSoC Creator中。之后,当你打开PSoC Creator,在它的“开始页面”,你会看到工具包下的工具包和解决方案。如果你点击工具包,页面将用链接打开以打开处理器模块和底板的示意图。问候,Bobby
以上来自于百度翻译 以下为原文 If you download the CY8CKIT-001 software (www.cypress.com/go/cy8ckit-001) it will install the kit into PSoC Creator. After that, when you open up PSoC Creator, on its 'Start Page' you will see the kit under 'Kits and Solutions'. If you click on the kit, the page will update with links to open PDFs for the schematic of the processor module and the baseboard. Regards, Bobby |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
276浏览 2评论
171浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 05:40 , Processed in 0.819661 second(s), Total 46, Slave 40 queries .
