大家好,如果我想在我们的SA中输入一个弱信号而没有内部前置放大器选项,我会用一个增益为30dB,NF 6dB的外部前置放大器代替。
从安捷伦应用笔记中,前置放大器将降低仪器的DANL,但我可能知道这个噪声系数规格会影响读数的准确性吗? 例如,添加前置放大器后-60dbm输入功率读数会变差吗? 谢谢你的确认。 以上来自于谷歌翻译 以下为原文 hi all, if i would like to input a weak signal into our SA and without the internal pre amp option, i am substituting an external pre amp with gain like 30dB, NF 6dB. from Agilent application note, the pre amp will lower down the DANL of the instrument, but may i know will this noise figure spec affecting the accuracy of the reading? example, -60dbm input power reading become worse after adding the pre amp? thanks you for the confirmation. |
嗨 - 根据SA型号,您可以将外部前置放大器增益值输入分析仪。
完成此操作后,本底噪声将降低,信号幅度也应正确读取。 如果外部前置放大器增益没有物理软键,您还可以使用参考电平偏移功能。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - Depending on the SA model, you may be able to enter the external preamplifier gain value into the analyzer. Once this is done the noise floor will decrease and the signal amplitudes should also all read correctly. If there is not a physical softkey for external preamplifier gain, you can also use the reference level offset feature. Regards - |
1030 浏览 0 评论
2276 浏览 1 评论
2063 浏览 1 评论
1933 浏览 5 评论
2806 浏览 3 评论
797浏览 1评论
582浏览 0评论
676浏览 0评论
2462浏览 0评论
1519浏览 0评论
GMT+8, 2024-9-20 11:54 , Processed in 1.097835 second(s), Total 43, Slave 38 queries .
