扫一扫,分享给好友
你好,
我有许多成功的PSoC 3和5个项目下的皮带,包括一些相当复杂的设计。 然而,我从来没有使用PSoC 1 -但是! 那么了解PSoC 1最好的方法是什么?你会推荐哪种开发工具? 以上来自于百度翻译 以下为原文 Hi, I have many succesful PSoC 3 and 5 projects under the belt, including some quite complex designs. However I have never used PSoC 1 - yet! So what's the best way to get to know PSoC 1? Which dev kit would you recommend? |
21个回答
您不需要一个POD将ICE连接到KIT-1001的PSOC1处理器模块。已经有一个连接器,其中插入了冰,PSoC1设备是一个特殊的设备,它已经具备了像POD中的芯片一样的必要调试能力。
鲍勃 以上来自于百度翻译 以下为原文 You do not need a POD to connect the ICE to a PSoC1 processor module for the Kit-001. There is already a connector where the ICE is plugged in and the PSoC1 device is a special one that already has got the necessary debug-capabilities like the chip in the POD. Bob |
确保没有混淆。对于试剂盒,- 001,有一个特定的
处理器用于PSoC 1,具有特定数量的Flash、I/O等。所以 你可以调试W/O POD脚,目标是-001,以及处理器。 但是一旦你决定开发你自己的项目,你需要吊舱和脚。 适用于您选择的零件/包装。 HTTP://www. CyPress?COM/?RID=3288 问候,Dana。 以上来自于百度翻译 以下为原文 To make sure there is no confusion. For the kit, -001, there is a specific processor used for PSOC 1, with a specific amount of FLASH, I/O, etc.. So you can debug that w/o pod feet, as your target is the -001, and that processor. But once you decide to develop your own project you need the pod and feet applicable to the part/package you choose. http://www.cypress.com/?rID=3288 Regards, Dana. |
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
570浏览 2评论
423浏览 2评论
437浏览 2评论
384浏览 2评论
915浏览 2评论
GMT+8, 2024-12-23 20:35 , Processed in 0.721285 second(s), Total 48, Slave 42 queries .
