扫一扫,分享给好友
你好,
我有许多成功的PSoC 3和5个项目下的皮带,包括一些相当复杂的设计。 然而,我从来没有使用PSoC 1 -但是! 那么了解PSoC 1最好的方法是什么?你会推荐哪种开发工具? 以上来自于百度翻译 以下为原文 Hi, I have many succesful PSoC 3 and 5 projects under the belt, including some quite complex designs. However I have never used PSoC 1 - yet! So what's the best way to get to know PSoC 1? Which dev kit would you recommend? |
21个回答
嗨,SpiderKenny,
对不起,延迟答复,您可能已经购买了您想要的工具包。但我想补充说,从PSoC 1开始的最简单和最经济的方法是CY32 10-PSoCalv1工具包-HTTP://wwwyCypCy.COM/?RID=2541。这个套件附带CY8C946624PXI和CY8C27 43-24PX样品。它有大量的面包空间,你可以用在你的设计上。除此之外,如果您正在寻找调试功能,您可以购买ICE立方体(CY32 15—DK)。 PSoCalv1工具包可在英国FANNELL商店-HTPU//UK.FARNELL.COM/CyPress -半导体/CY32 10-PSoValeD1开发-KIT-BASIC-PSOC/DP/1321702 当做 安舒尔 以上来自于百度翻译 以下为原文 Hi SpiderKenny, Sorry for a delay in replying, you may have already purchased your desired kit. But I wanted to add that the simplest and the most cost efficienct way to get started with PSoC 1 is but the CY3210-PSoCEval1 kit - http://www.cypress.com/?rID=2541. This kit comes with CY8C29466-24PXI and CY8C27443-24PX samples. It has plenty of breadborad space which you can use for your design. In addition to this if you are looking for debugging capabilities you can purchase an ICE-Cube (CY3215-DK). The PSoCEval1 kit is available in UK Farnell store - http://uk.farnell.com/cypress-semiconductor/cy3210-psoceval1/development-kit-basic-psoc/dp/1321702 Regards Anshul |
添加到Anshul的链接到…如果你想开始使用PSoC1,你有一个更便宜和负担得起的选项,形式是简单的PSoC1:HTTP://EntEsL.COM/EASY-PSoC1开发板
以上来自于百度翻译 以下为原文 To add to what Anshul liinked to... If your looking to get started with PSOC1 you have an even cheaper and affordable option in form of EASY PSOC1: http://entesla.com/easy-psoc1-development-board |
如果你认为我错了,请指正我:在设计专业时,你确实需要调试能力。所述开发板连接到PC,但不允许设置断点或检查变量等。
尽管如此,这是一个非常便宜的突破板。 鲍勃 以上来自于百度翻译 以下为原文 Correct me, if you think I'm wrong: You do need debug capabilities when designing professionally. The mentioned development board connects to a PC but it does not allow to set breakpoints or inspect variables etc. Nonetheless it is a very cheap breakout board. Bob |
你好,
这是一个很好的讨论,因为我也希望从PSoC开发开始,特别是PSoC 1,因为它的模拟灵活性和低成本。 有人告诉我,3210个PoSoCales是走的路,是最便宜的柏树套件,是一个完整的开发套件。还发现了大量的例子,它的芯片(+塑料蘸包是伟大的,为我的需要) 唯一的问题是它几乎从来没有在柏树网站(太多购买它:): 当我等待我的董事会到来时,我在想为什么我需要一个ICE调试器(我已经阅读了调试手册,太棒了)。但是每个人都需要如此昂贵和先进的调试方法吗? 欢呼,SF 以上来自于百度翻译 以下为原文 Hello, This is a nice discussion, since I'm also looking to start with PSoC development, especially PSoC 1 given it's analog flexibility and low cost. I was told 3210 PSOCEVAL is the way to go, and is the cheapest Cypress kit that is a full development kit. Also found tons of examples for the chips it comes with (+Plastic DIP package is great for my needs) Only problem is it almost is never in stock in the Cypress website (too many buying it eh :) ) As I'm waiting for my board to arrive, I'm thinking why I would need an ICE debugger (I have read the debugging manual, it was fantastic). But would everyone need such an expensive and advanced method for debugging? Cheers, SF |
欢迎来到PSoC世界!
我很欣赏你的调试方法的想法。对于不同的调试方法,您是正确的。 冰(仿真器)是一个功能强大的硬件调试先进的逻辑,例如,它可以通过硬件比较动态的断点,不影响你的芯片代码的执行时间。 不过,也有其他选项,如UART、I2C的调试。I2C接口随着桥梁的控制面板软件已经使用了很长的时间来调试CapSense应用。调试应用笔记给出了一些例子,UART,I2C可作为冰替代看寄存器/读取数据调试。 我们正在不断寻找简化PSoC用户开发过程的方法。欢迎您的意见/建议! 以上来自于百度翻译 以下为原文 Welcome to the world of PSoC! I appreciate your thoughts on debugging approaches. You are right about different approaches to debugging. The ICE (In-Circuit Emulator) is a powerful piece of hardware for debugging advanced logic, for e.g., it can dynamic breakpoints by hardware compare, and does not affect timing of code execution in your chip. Still, there are other options such as UART/I2C based debugging. I2C interface along with the Bridge Control Panel software has been used for a long time to debug CapSense applications. The debugging appnote gives some examples on how UART and I2C can be used as an ICE alternative for watching registers/ reading data for debugging. We are constantly looking at ways to simplify the development process for PSoC users. Your thoughts/suggestions are always welcome! |
由于跟踪、内存视图、逻辑跟踪能力,ICE通常会使您更有效率。
通过UART、I2C桥或将变量写入LCD进行简单调试是可行的,但不是灵活的。它可以通过为链接的两边写一个广泛的API而变得更加灵活。 PSoC 3/5调试是基于USB连接器,或MIXPRO3,可以作为桥梁或调试或程序员使用。注意这很大程度上是由PSoC 3/5中的片上调试逻辑促成的。3 / 5的一个限制,在PSoC 1的存在,没有豆荚/脚用于最终用户设计的原始套接字。3 / 5的开发板是你的平台,一些引脚,HW承认,但通常这不是一个显示。其实可以很使没有创建自己的基本原试验台。事实上,3/5板方法可以节省你$$整体。 在PSoC调试视频,1去这里(否则就去www.cypress.com,3/5段视频)。 HTTP://www. CyPress?COM/?ID=1573和rTID=337 问候,Dana。 以上来自于百度翻译 以下为原文 The ICE generally makes you more productive, due to trace, memory views, logical trace capability. Simple debugging via UART, I2C bridge, or writing variables to LCD is workable, but not as flexible. It could be made more flexible by writing an extensive API for both sides of the link. PSOC 3 / 5 debugging is bases on USB connector, or Miniprog3 which can be used as a bridge or as debug or programmer. Note this is largely facilitated by onchip debug logic in PSOC 3/5. One limitation of 3/5, that exists in PSOC 1, is no pods/feet for use in end user design proto socket. 3/5 the dev board is your platform, some pins, HW comitted, but generally this is not a show stopper. Actually can be very enabling not having to create your own basic proto test bed. In fact 3/5 board approach can save you $$ overall. There are videos on PSOC debugging, for 1 go here (otherwise just go to www.cypress.com, video section for 3/5). http://www.cypress.com/?id=1573&rtID=337 Regards, Dana. |
这是一个容易回答的问题:
但是 你真的需要一个冰块来获得更多的调试功能,而不仅仅是灯关灯。 获得一个3270套件或使用-001板与通用PSoC1处理器模块,前者的优势是PSoC1的DIL包,使其易于处理,即使在面包板,而后者有必要的调试硬件集成,不需要一个POD连接到ICE。 鲍勃 以上来自于百度翻译 以下为原文 That's an easy-to-answer-question: ANY But You'll REALLY need an ICE-Cube to get more debugging features than only Lamp-on-Lamp-off. Get a 3270 Kit or use the -001 board with the universal PSoC1 processor module, the former has the advantage of the PSoC1 coming in a DIL-package making it easy to handle even on breadboards while the latter has the necessary debug-hardware integrated and doesn't need a pod to connect to the ICE. Bob |
嗨,鲍伯
谢谢你的回复 我不介意处理SOIC,甚至QFN -所以不用担心: 我看001个工具箱听起来很有趣。 再次感谢。 -肯尼 以上来自于百度翻译 以下为原文 Hi Bob Thanks for the reply I don't mind handling SOIC or even QFN - So no worries there :-) I'll look at the 001 kit - sounds interesting. Thanks again. -Kenny |
我忘了提:
当订购冰块时,标准POD交付的是CY8C9466PXI,它是以DIL包来的。所以当你使用它的时候,你最好用一个3210开发包。 塔克卡!!!!当我试图删除处理器模块时,我杀死了我的001板。其中一个连接器断开(LCD端口2) 鲍勃 以上来自于百度翻译 以下为原文 I forgot to mention: When ordering an ICE-Cube, the standard POD delivered is for the CY8C29466-PXI which comes in a DIL-Package. So when you are using that you'll go best with a 3210 dev Kit. TAKE CARE!!! I killed my -001 board when I tried to remove the processor module. One of the connectors went off (port 2 for the LCD) Bob |
六羟甲基三聚氰胺六甲醚。
我找不到一个“001”套件在我平常的供应商(法内尔,英国)。 我有点害怕从CyPress商店订购,以防我的进口关税受到冲击,就像上次一样。 以上来自于百度翻译 以下为原文 Hmmm. I can't find an '001' kit at my usual supplier (Farnell, UK). I'm a bit scared to order from the cypress store in case I get hit with loads of import duty like last time. |
我开始使用冰块和PSoVale1套件,后者成本很低。
001是更灵活的,但需要冰块调试。 问候,Dana。 CY32 10SpOsValue112(1)PDF 779.4 K 以上来自于百度翻译 以下为原文 I started using an ICE Cube and a PSOCEval1 kit, the latter quite low cost. The 001 is more flexible, but needs the ICE Cube to debug. Regards, Dana.
@ SpiderKenny
这是在Farnell.co.uk:HTTP:/UK.FARNELL.COM/CyPress -半导体/CY8CKIT-01B/KIT-Dealth-PSOC-3-5/DP/No.808432 快乐订购 鲍勃 以上来自于百度翻译 以下为原文 @SpiderKenny Here it is at Farnell.co.uk: http://uk.farnell.com/cypress-semiconductor/cy8ckit-001b/kit-development-psoc-3-5/dp/1908432 Happy ordering Bob |
这是冰块HTTP:/UK.FARNELL.COM/CyPress半导体/CY32 15DK/IN电路仿真开发/DP/1631239。
鲍勃 以上来自于百度翻译 以下为原文 ...and this is the ICE-Cube http://uk.farnell.com/cypress-semiconductor/cy3215-dk/in-circuit-emulation-development/dp/1631239 Bob |
嗨,鲍伯
感谢链接-第一个似乎是PSoC3/5而不是PSoC 1 -肯尼 以上来自于百度翻译 以下为原文 Hi Bob thanks for the links - the first one seems to be for psoc3/5 rather than Psoc 1 -Kenny |
法内尔有一个不完整的描述。在CyPress网站上购买KIT-01B的开发工具包,您可以看到它也是PSOC1的设计工具。法纳尔忘记了。
鲍勃 以上来自于百度翻译 以下为原文 Farnell had an uncomplete description. Check at the Cypress site Buy -> Development Kits for the Kit-001b there you can see that it is designerd for PSoC1 as well. Farnell forgot that. Bob |
谢谢鲍伯对我这么冷淡!
我会给你一个机会: 以上来自于百度翻译 以下为原文 Thanks Bob for being so paitent with me! I will give that a go :-) |
@ SpiderKenny
…请记住,即使KIT-01B没有为PSoC1提供任何调试功能,您也需要冰块。 鲍勃 以上来自于百度翻译 以下为原文 @SpiderKenny ... and keep in mind that even the Kit-001b does not offer any debug-capabilities for PSoC1, you'll need the ICE-cube. Bob |
记住在使用冰块时要根据你的包装
需要不同的豆荚来配合你的包装选择。这个 ICE是一个基本的仿真器,所以仿真电缆的末端必须 终止在适配器/英尺在您的原/板使用。 HTTP://www. CyPress?COM/?RID=3411 问候,Dana。 以上来自于百度翻译 以下为原文 Keep in mind when using ICE CUBE depending on package you need different pod feet to mate up to your package choice. The ICE is a basic emulator, so the end of the emulation cable has to be terminated in the adapters/feet to be used in your proto/board. http://www.cypress.com/?rID=3411 Regards, Dana. |
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
569浏览 2评论
423浏览 2评论
437浏览 2评论
383浏览 2评论
915浏览 2评论
GMT+8, 2024-12-23 17:00 , Processed in 1.563790 second(s), Total 114, Slave 98 queries .
