您好,
看手册Using the TMS320C6748_C6746_C6742 Bootloader spraat2f.pdf The C6748/C6746/C6742 bootloader supports NAND devices that comply with the ONFI standard. If a NAND device is ONFI-compliant, the bootloader reads device information from the NAND parameters page. 对于Micron NAND Flash型号:MT29F256G08, – Page size x8: 8640 bytes (8192 + 448 bytes) – Block size: 128 pages (1024K + 56K bytes) C6748 Bootloader支持不? 谢谢, |
3 个讨论
jj568318653 发表于 2019-1-24 06:43 如果nand flash支持onfi标准,那么c6748 rbl是支持的。 http://processors.wiki.ti.com/index.php/Determining_compatibility_between_ROM_Bootloader_(RBL)_and_Raw_NAND_devices#ONFI |
586 浏览 1 评论
427 浏览 1 评论
620 浏览 2 评论
910 浏览 3 评论
709 浏览 1 评论
193浏览 29评论
1156浏览 23评论
323浏览 20评论
286浏览 14评论
135浏览 13评论
GMT+8, 2025-2-3 21:06 , Processed in 0.690727 second(s), Total 47, Slave 41 queries .
