嗨,我正在使用Agilent Signal Studio进行LTE-LTE-Advanced FDD,以生成用于标准基站LTE测试的波形文件。
目标仪器是E4433B。 我必须为3GPP测试模型中定义的基站上行链路和下行链路生成波形。 请帮忙。 问候。 以上来自于谷歌翻译 以下为原文 Hi, I am playing with Agilent Signal Studio for LTE-LTE-Advanced FDD to generate waveform files for standard Base station LTE tests. Target Instrument is E4433B. I have to generate waveforms for Base station Uplink and Downlink defined in 3GPP test models. Please help. Regards. |
嗨tabbott,我能够找到一个E4438C加载许可证。
现在我正在运行LTE 5 MHz测试信号。 但是,没有选择创建符合TM 1.1的3GPP LTE测试模型信号; TM 3.1或A1-3; A1-5。 安捷伦是否支持此功能? BR。 以上来自于谷歌翻译 以下为原文 Hi tabbott, I was able to find one E4438C with licence to load. Now I am running LTE 5 MHz test signal coming out. However there are no option to create 3GPP LTE Test model signal which comply with TM 1.1; TM 3.1 or A1-3; A1-5. Is this feature supported by Agilent? BR. |
yanan101114 发表于 2019-1-23 18:57 嗨 - 在树状菜单中为基本LTE FDD R9载波选择下行链路,您将看到我们在主屏幕中有一个测试模型向导按钮。 单击它将打开TM向导,并允许您选择TM 1.1到TM 3.3用于基站一致性测试类型。 要查看A1-3或A1-5的FRC,您需要拥有Advanced LTE FDD Uplink运营商。 然后在树状菜单中选择Uplink将为您提供UL FRC向导的单选按钮。 打开将允许您选择所需的参考通道。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - Select Downlink in the tree menu for a Basic LTE FDD R9 carrier, and you will see that we have a Test Model Wizard button in the main screen. Clicking on that will open the TM Wizard and allow you to select the TM 1.1 through TM 3.3 for Base Station conformance test types. To see the FRCs for A1-3 or A1-5, you will need to have an Advanced LTE FDD Uplink carrier. Then selecting Uplink in the tree menu will give you the radio button for UL FRC Wizard. Opening that will allow you to select the Reference Channel you want. Regards - |
1287 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2064 浏览 5 评论
2951 浏览 3 评论
1111浏览 1评论
753浏览 0评论
926浏览 0评论
1287浏览 0评论
GMT+8, 2024-12-24 00:31 , Processed in 1.835257 second(s), Total 80, Slave 64 queries .
