McCVIEW:V3.36MPLAB X版本:V4.00 OS:Windows 10 Pro Cube:GUI(或生成代码)设备:PIC32 MM0256GPM028在MCC的最新版本中,PIC32 MM0256GPM028设备,PIN号20可用作配置的RB12。然而,在数据表中,该PIN被定义为USB外围设备。AL电源引脚,不能用作GPIO引脚。PIN应该根据数据表被绑定到VDD3V3或GND。因此,在MCC中,这个引脚作为RB12的可配置性是错误的。亲切的问候,汉斯。
以上来自于百度翻译 以下为原文 MCC version: v3.36 MPLAB X version: v4.00 OS: Windows 10 Pro Area: GUI (or Generated Code) Device: PIC32MM0256GPM028 In the latest version of MCC, with the PIC32MM0256GPM028 Device, pin number 20 is available as RB12 for configuration. However, in the datasheet, this pin is defined as the USB peripheral supply pin, and can not be used as an GPIO pin. The pin should be tied toi VDD3v3 or to GND according to the datasheet. As such, it seems that the configurability of this pin as RB12 in the MCC is a mistake. Kind regards, Hans |
谢谢你指出这一点。PIN应该绑定到VUSB 3V3,它将在PIC24DSPIC33-PIC32 MM库的未来版本中得到更正。
以上来自于百度翻译 以下为原文 Thank you for pointing this out. The pin should be tied to VUSB3V3 and it will be corrected in future releases for the pic24-dspic33-pic32mm library |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3106 浏览 3 评论
2177 浏览 5 评论
618浏览 1评论
495浏览 1评论
351浏览 1评论
520浏览 0评论
427浏览 0评论
GMT+8, 2024-9-22 07:14 , Processed in 0.856054 second(s), Total 43, Slave 38 queries .
