在PIC16LF18326上,有一个PLL设置,使一个内部的32 MHz振荡器,但是32兆赫也可以不启用PLL。附表显示了这一点。因此,除了24MHz的额外频率之外,PLL选项的意义是什么?使用32个没有PLL的MHz是否有一些优点或缺点?谢谢
以上来自于百度翻译 以下为原文 Hi regarding PIC16LF18326 there is a PLL setting that enables an internal 32MHz oscillator, however 32MHz is also available without PLL enabled. The attached table shows this. So aside from the additional frequency of 24MHz, what is the point of having the PLL option? Is there some advantage or disadvantage in using 32MHz without PLL enabled? thanks Attached Image(s) |
4个回答
PLL将允许外围设备在16MHz下运行,而内核运行在32(或12/24或8/16)。我同意这似乎是一个小事情,但我认为,因为PLL是有外部来源反正它很少有门来运行HFIFT通过它(并重新路由一些信号和改变NDIV从4到2)。虽然表35-2显示Idd 2.2Ma在32 MHz无论PLL,我WoulD认为在较低的频率下运行外围设备有一定的省电。加上计时器延迟可以是两倍长(最大值)。
以上来自于百度翻译 以下为原文 The PLL would allow peripherals to run at 16MHz while the core runs at 32 (or 12/24 or 8/16). I would agree that this seems like a small thing, but I suppose since the PLL is there for external sources anyway it took very few gates to run the HFINT through it (and reroute a few signals and change the Ndiv from 4 to 2). Although table 35-2 shows Idd as 2.2mA at 32MHz regardless of PLL, I would think there is some power saving from running peripherals at the lower freq. Plus timer delays could be twice as long (at max). |
我认为外围设备与CPU的时钟相同,不管怎样。
以上来自于百度翻译 以下为原文 I think the peripheral runs on the same clock as CPU no matter what. |
一些外围设备可以直接从HFIFToC而不是Fosc或FoCC/4(例如,TMR0,NCO)运行。
以上来自于百度翻译 以下为原文 Some peripherals can run directly from HFINTOSC instead of Fosc or Fosc/4 (e.g., TMR0, NCO). |
5367 浏览 9 评论
2099 浏览 8 评论
2003 浏览 10 评论
3276 浏览 3 评论
2309 浏览 5 评论
876浏览 1评论
765浏览 1评论
704浏览 1评论
762浏览 0评论
651浏览 0评论
GMT+8, 2025-3-5 10:08 , Processed in 1.167890 second(s), Total 48, Slave 43 queries .
