你好,
我试图调试一个CY8CKIT-059(CY8C588Lti-LP097设备)编程与Acode示例从CyPress与MixPrim3和PSoC创建者4。 程序员和设备目标是可见的,我能够连接到设备(使用外部或3.3/5VTARG电源)。这个项目建立得很好,我在命令窗口中得到一个输出,说明目标已经被正确地编程了。 然后,当它试图切换到调试模式时,我得到这个错误: “错误:dg.M90015:调试器在运行期间意外退出。遇到错误(目标断开参见输出窗口以获取更多信息)。 显示细节标签: “调试会话期间存在未处理的错误。这就迫使调试器关闭。再试一次。” 即使我再试一次,它也不起作用。 然后我试着用PSoC Creator 3.3,我可以调试。有人能在PSoC造器4上解决这个问题吗? 当做, 沙维尔 以上来自于百度翻译 以下为原文 Hello, I am trying to debug a CY8CKIT-059 (CY8C5888LTI-LP097 device) programmed with a code example from Cypress with a MiniProg3 and PSoC creator 4.0 . The programmer and device target are visible and I am able to connect to the device (using external or 3.3/5Vtarg power supply). The project builds well and I get an output in the command window that says that the target has been properly programmed. Then, when it tries to switch to debug mode I get this error: "error: dbg.M0015: Debugger exited unexpectedly during run. Encountered error (Target disconnected See output window for more information." and the show details tab: "There was an unhandled error during the debug session. This has forced the debugger to shutdown. Try again." Even if I try again it does not work at all. Then I tried with PSoC Creator 3.3 and I am able to debug. Is somebody able to fix that problem on PSoC Creator 4.0? Regards, Xavier |
15个回答
欢迎来到论坛,沙维尔。
检查工作区-gt;系统& gt;调试设置被设置为SWD而不是GPIO。 鲍勃 以上来自于百度翻译 以下为原文 Welcome in the forum, Xavier. Check that in Workspace -> System -> Debug settings is set to SWD and not to GPIO Bob |
我找不到这个菜单。它在哪里? 当我选择调试目标时,我可以选择JTAG和SWD之间,并选择SWD。 沙维尔 以上来自于百度翻译 以下为原文 I can't find this menu. Where is it? When I go to select debug target, I can choose between JTAG and SWD, and SWD is chosen. Xavier |
WorkStudio Explorer & & G.和G.调试设置
鲍勃 以上来自于百度翻译 以下为原文 Workspace explorer -> System -> Debug settings Bob |
谢谢你的回答,鲍伯,但是我找不到thatin PSoC Creator 4。你能发送快照吗? 沙维尔 以上来自于百度翻译 以下为原文 I thank you for your answers Bob, but I can't find that in PSoC Creator 4.0 . Can you send a snapshot please? Xavier |
好的,谢谢!但它已经设置为SWD+SWV,我也尝试了SWD,并且我得到同样的错误… 以上来自于百度翻译 以下为原文 Ok, found it thanks! But it was already set to SWD + SWV, and I also tried SWD only, and I get the same error... |
您是否使用ARM GCC通用工具链或使用CyPress提供的默认工具链。
检查: 1、进入工具& GT;选项(见附图) 2、进入项目&建立设置(见附图) ARMG工具 39.6 K PNG 48.5 K 以上来自于百度翻译 以下为原文 Are you using ARM GCC Generic Toolchain or using the Default toolchain provided by Cypress. Check that by- 1.Going to Tools>Options(see the attached image) 2.Going to Projects>Build Settings(see the image attached)
柏树所提供的。 以上来自于百度翻译 以下为原文 The one provided by Cypress. |
请检查优化级别是否设置为“否”(如附图所示)
优化水平 49.6 K 以上来自于百度翻译 以下为原文 Please check whether the optimization level is set to none or not (as shown in image attached)
请提供我们正在调试的项目,我们将首先在CY8CKIT-059上复制我们这边的问题。
以上来自于百度翻译 以下为原文 Please provide us with the project you are debugging,we will try to reproduce the issue at our side first on CY8CKIT-059 . |
它是Cypress的代码示例工具包提供的基础设计项目。事实上,没有任何改变。但是,它也从工具箱中的每个代码示例中做到这一点。我去文件& GT;新& GT;项目…检查目标工具包:CY8CKIT-059,下一个代码示例,然后我选择一个项目,然后单击FEAR。 我正在运行Windows 10家庭100.14339,英特尔I5-3570K 3.4GHz,64位 以上来自于百度翻译 以下为原文 It is the BasicDesign01 project provided by Cypress' code example kit for the CY8CKIT-059. It is as is, no changes made. But, it also does that with every code example from the kit. I go File -> New -> Project... Check target kit: CY8CKIT-059, next and code example, then I choose an item and I click finish. I am running windows 10 Home 10.0.14393, Intel i5-3570K 3.4GHz, 64 bits |
请将您的生成设置的快照发送到PC4.0
以上来自于百度翻译 以下为原文 Please send the snapshot of your build settings in PC4.0 |
请尝试“附加到正在运行的目标”选项给Debug tab pc4.0下调试项目规划后的设备。
更清晰地附上图片。 AutoChytoToTalk.PNG 89 K 以上来自于百度翻译 以下为原文 Please try "Attach to Running Target" Option Given under Debug tab in PC4.0 for debugging the project after Programming the device. Attaching a pic for more clarity.
766个成员聚集在这个小组
加入小组2205 浏览 1 评论
1947 浏览 1 评论
3778 浏览 1 评论
1869 浏览 6 评论
1611 浏览 1 评论
1402浏览 2评论
693浏览 2评论
521浏览 2评论
499浏览 2评论
1378浏览 2评论
GMT+8, 2025-4-22 18:58 , Processed in 1.212861 second(s), Total 70, Slave 65 queries .
