扫一扫,分享给好友
嗨,
我有设计工具的浮动许可证,我获得了另一个节点锁定许可证,用于部分重新配置。 我使用Ubuntu,我无法安装部分重新配置的许可证。 我试过这个: export LM_LICENSE_FILE = 2100 @ SERVERexport LM_LICENSE_FILE = / home / user / .license / Xilinx_PR.lic 但它没有用。 我该怎么处理? 感谢您的帮助。 阿卜杜拉 以上来自于谷歌翻译 以下为原文 Hi, I have floating license for design tools and I got another node-locked license for partial reconfiguration. I use Ubuntu and I could not install the license for partial reconfiguration. I tried this: export LM_LICENSE_FILE=2100@SERVER export LM_LICENSE_FILE=/home/user/.license/Xilinx_PR.licBut it didn't work. How can I handle it? Thank you for your help. abdullah |
3个回答
将新功能添加到许可证文件后,是否重新启动了许可证服务器?
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 After you added the new feature to the license file did you restart the license server? ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
lmstat报告许可证是什么?
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 What does lmstat report for the licenses? ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2580 浏览 7 评论
2914 浏览 4 评论
2367 浏览 9 评论
3466 浏览 0 评论
2547 浏览 15 评论
3021浏览 1评论
711浏览 1评论
581浏览 1评论
875浏览 0评论
GMT+8, 2025-4-10 22:11 , Processed in 1.298831 second(s), Total 81, Slave 65 queries .
