你好。
我正在尝试修复旧的HP 33120A。 测试报告几乎没有错误: - “603波形RAM回读失败” - “604调制RAM回读失败”(这个似乎通过更换32k x 8 SRAM存储器来修复) - “606波形ASIC失败” - “608 SYNC信号检测失败 ,椭圆滤波器路径“我的猜测是”606波形ASIC失败“是由于SRAM内存更加失败。 不幸的是,这个旧版本/型号使用古老的TC55417J-15H(SOJ24封装)16k x 4类型的SRAM。 这些种类看起来不再生产。 所以: - 寻找HP 33120A原理图(不是Agilent 33120A,因为Agilent变体使用模式内存,而我的HP 33120A使用一些古老的,没有一个现在卖的现在类型的内存) - 任何人都有TC55417J-15H引脚排列,所以我可以替换它 用现代的东西? 我发现这是:“内存类别SRAM芯片组织密度66 kbits字数16 k Bits每字4位封装封装类型SOJ,0.300 INCH,PLAStiC,SOJ-24引脚24逻辑系列CMOS电源特性电源电压5V访问时间 15 ns工作温度0到70 C(32到158 F)“所以看起来很奇怪。 以上来自于谷歌翻译 以下为原文 Hi. I'm trying to fix old HP 33120A. Test reports few errors: - "603 Waveform RAM readback failed" - "604 Modulation RAM readback failed" (this one seems to be fixed by replacing 32k x 8 SRAM memory) - "606 Waveform ASIC failed" - "608 SYNC signal detection failure, Elliptical filter path" My guess is that "606 Waveform ASIC failed" is due to more failed SRAM memory. Unfortunately this old revision/model uses ancient TC55417J-15H (SOJ24 package) 16k x 4 type of SRAM. These kinds look no longer produced. So: - looking for HP 33120A schematic (not Agilent 33120A since Agilent variant uses moden memory while my HP 33120A uses some ancient, no-one-sells-now type of ram) - anyone having TC55417J-15H pinout, so I could replace it with something modern? I found that this is: "Memory Category SRAM Chip Organization Density 66 kbits Number of Words 16 k Bits per Word 4 bits Packaging Package Type SOJ, 0.300 INCH, PLASTIC, SOJ-24 Pins 24 Logic Family CMOS Power Characteristics Supply Voltage 5V Access Time 15 ns Operating Temperature 0 to 70 C (32 to 158 F) " so looks like a weird one. |
3个回答
发现内存的数据表(好,类似的部分):http://www.digchip.com/datasheets/parts/datasheet/710/TC55417J-15H-pdf.php所以现在只寻找旧的HP 33120A原理图。
以上来自于谷歌翻译 以下为原文 Datasheet for memory found (well, similar part): http://www.digchip.com/datasheets/parts/datasheet/710/TC55417J-15H-pdf.php So now only looking for old HP 33120A schematic. |
diaoshayu 发表于 2019-1-22 13:41 您好,原理图可在服务指南中找到:http://cp.literature.agilent.com/litweb/pdf/33120-90017.pdf 以上来自于谷歌翻译 以下为原文 Hello the schematics are available in the service guide: http://cp.literature.agilent.com/litweb/pdf/33120-90017.pdf |
4864165sas 发表于 2019-1-22 13:52 该原理图适用于安静修订。 安捷伦做了一些细微的修改,不同的部件(例如完全不同的sram内存,更改了部件的位置和部件的数量等)。因此,我正在寻找HP修订版的示意图,然后才能改变安静。 安捷伦发布了旧的hp手册(新的,安静的),但没有旧的(hp)服务指南。 以上来自于谷歌翻译 以下为原文 This schematic is for agilent revision. Agilent made slight modifications, different parts (like totally different sram memory, changed components location and numbers for some parts) etc. Thus I'm looking for a schematic to HP revision, before agilent changed things. Agilent published old hp manual (new, agilent one too) but no old (hp) service guide. |
1394 浏览 0 评论
2424 浏览 1 评论
2275 浏览 1 评论
2112 浏览 5 评论
3027 浏览 3 评论
1488浏览 1评论
837浏览 0评论
1252浏览 0评论
1394浏览 0评论
GMT+8, 2025-3-6 03:38 , Processed in 1.400142 second(s), Total 79, Slave 64 queries .
