在25LC256 SPI EEPROM上,我的硬件设计者一直保持WP(PIN 3)为NC。那么在这种情况下,WP的地位如何呢?它能写入设备,还是被保护?
以上来自于百度翻译 以下为原文 On 25LC256 SPI EEPROM, My hardware designer have kept WP (pin 3) as NC. So what will be status of WP in that case. Will it be able to write to device, or it will be protected? |
4个回答
任何离开输入引脚浮动的硬件设计者都应该被踢出。这是不可原谅的。你无法预测会发生什么。它可能浮低,可能浮动高,或者它可以拿起主频,开关在50-60Hz的高和低。它将非常与温度,湿度和周围电场。
以上来自于百度翻译 以下为原文 Any hardware designer who leaves an input pin floating should be kicked out. That's unforgiveable. You cannot predict what will happen. It may float low, it may float high, or it may pick up the mains frequency an switch high and low at 50-60 Hz. It will very with temperature, humidity, and surrounding electric fields. |
是的,你是对的。事实上,我们以前使用的是2K640 SPI SRAM,但后来我们决定使用25LC256。两个引脚兼容,除了第三针。因此,硬件设计是参考SRAM的。多哈…但我们在这里使用EEPROM GRIN:还有一件事,我想问的是,有没有其他的EEPROM(或闪存,或任何内存大约512kByb),由任何其他制造商,这是PIN兼容与23 K640 SPI SRAM?
以上来自于百度翻译 以下为原文 Yeah qhb you are correct. Actually we were previously gonna use 23K640 SPI SRAM, but later we decided to use 25LC256. Both are pin compatible, except 3rd pin. So hardware design was with reference to SRAM. duhhhhh..... but we used here EEPROM grin: . One more thing I want to ask is, Is there any other EEPROM (Or Flash, or anything that has memory of around 512KBytes) , by any other manufacturer, which is pin compatible with 23K640 SPI SRAM? |
你很幸运。从数据表中,当状态寄存器中的WPEN位较低时,WP PIN功能被阻塞。这允许用户在WP PIN GRUNDED系统中安装25XX256,并且仍然能够写入状态寄存器。当WPEN位设置为高时,WEP引脚功能将被启用。
以上来自于百度翻译 以下为原文 You are lucky. from data sheet : The WP pin function is blocked when the WPEN bit in the STATUS register is low. This allows the user to install the 25XX256 in a system with WP pin grounded and still be able to write to the STATUS register. The WP pin functions will be enabled when the WPEN bit is set high. |
非常感谢,这将是非常有益的反应。
以上来自于百度翻译 以下为原文 Thanks a lot, This will be really helpful response. |
5308 浏览 9 评论
2070 浏览 8 评论
1974 浏览 10 评论
3243 浏览 3 评论
2280 浏览 5 评论
828浏览 1评论
721浏览 1评论
665浏览 1评论
718浏览 0评论
616浏览 0评论
GMT+8, 2025-1-27 14:03 , Processed in 1.068533 second(s), Total 83, Slave 67 queries .
