我用先锋CY8CKIT-042-BLE完成了一个项目。我试图找到一个简单的突破板,我可以塞入CY8CKIT-142模块,以演示项目给客户。我四处搜寻,但运气不好。
以上来自于百度翻译 以下为原文 I finished a project using the Pioneer CY8CKIT-042-BLE. I am trying to find a simple breakout board that I can plug the CY8CKIT-142 module into to demo the project to the customer. I have searched around but no luck. |
4个回答
你可以使用一个ARDUINO断路板,并将其插入到创业板。你没有说出你需要的尺寸。亚马逊和其他人在阿杜诺盾牌部分。
以上来自于百度翻译 以下为原文 You can use an Arduino break out board and plug it in to the Pioneer Ble board. You didn't state the size you required . Amazon and others have them in the Arduino shield sections. |
很抱歉,你想把BLE模块插入一个突破。你需要制作自己的突破板。PIN OUT布局是在用户指南PDF页面120中有用于制作自己的板的信息。
链接:HTTP://wwwyCysP.COM/FIL/229 211下载 以上来自于百度翻译 以下为原文 I am sorry you want to plug in the Ble module to a breakout. You would need to make your own breakout board. the pin out layout is in the user guide PDF page 120 has the information for making your own board. Link: http://www.cypress.com/file/229211/download |
你好,
我需要类似的东西,并开始尝试删除模块的头,这是一个有点不起动器。认为这需要热气和一些耐心。最后,我用DRIMEL来切断尽可能多的模块头(确保没有短路),然后焊接到我需要的头引脚上。 不幸的是,这两个模块头不在一个“0.1”间距,所以你不能轻易附加到一块Velo板。您可以形成0.1个“头”轻微,并可以创造性地与这种类型的垂直安装头: HTTP://UK.FARNELL.COM/GULULL CONTROREST威廉希尔官方网站 /BG301-04-A0540-L B/Booad to Tab-Dead /DPosiD/DP/2458465 这可以让你对插销的偏移足够大,但总是很紧。 什么样的特点会成为一个好的突破板。例如: 1)0.1个“孔”的矩阵 2)CR2032电池座 3)LED 4)最小的尺寸,还是大量的面积增加更多的组件? 当做 齐格斯 以上来自于百度翻译 以下为原文 Hi, I needed something similar and started by trying to desolder the headers from the module, which was a bit of a non-starter. Think it would require hot-air and some patience. In the end, I used a dremel to cut of as much of the module headers as I could (Ensuring no shorts were left), and then soldered onto the header pins where I needed to. Unfortunately, the two module headers are not on a 0.1" pitch, so you can't easily attach to a piece of vero-board. You can form 0.1" headers slightly, and can get creative with this type of header mounted vertically: http://uk.farnell.com/global-connector-technology/bg301-04-a-0540-l-b/board-to-board-header-4-position/dp/2458465 This may allow you to offset the pins by roughly enough, but it's always a tight fit. What features would make a good breakout board. E.g. : 1) Matrix of 0.1" holes 2) CR2032 battery holder 3) LED's 4) Minimal size, or plenty of area to add more components? Regards Zigs |
如果你想要一个突破板的PSoC Module(CyBLY-01400—832引脚SMT模块),我做了以下和AM分享:
HTTPS://OsHPARK.COM/SyrDyPrimeSt/QMeXKBSL 它有一个24引脚dip足,KitProginterface的头,双LED板上。如果需要的话,请与我联系。 编辑:我在这里附上了图式和版面的图片,我张贴后没有看到它们。 PSOC模块 73.8 K PSOC模块 52.4 K 以上来自于百度翻译 以下为原文 If you want a breakout board for the PSoC Module (CYBLE-014008-00 32pin SMT Module) I have made the following and am sharing it: https://oshpark.com/shared_projects/qMexKBSl It has a 24 pin dip footprint, header for the KitProg interface, and a dual LED onboard. Contact me for the Eagle files if you need/want them. /edit: I have attached images of the schematic and board layout here, put I'm not seeing them after I post it...
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3449 浏览 0 评论
2302 浏览 1 评论
2020 浏览 1 评论
3864 浏览 1 评论
1921 浏览 6 评论
4106浏览 2评论
2628浏览 2评论
583浏览 2评论
560浏览 2评论
4385浏览 2评论
GMT+8, 2025-7-13 14:10 , Processed in 0.992966 second(s), Total 52, Slave 46 queries .
