我想把一个SRAM缓冲器中的8位数据转换成另一个SRAM缓冲器中的16位数据。数据字节可以孪生,因为稍后我将使用数字滤波器块进行插值。
我用DMA将数据从SRAM移至外围设备,外设到SRAM,但在我尝试从SRAM移动到SRAM的早期没有做任何事情。我相信我现在会明白的,因为我已经明白了。和格林; 我想尽可能快地做到这一点。我想我可以注册到一个寄存器中,然后从寄存器中取出,但是PSoC只支持8位寄存器。 有什么建议吗? 提前感谢! 以上来自于百度翻译 以下为原文 I would like to convert and move 8 bit data in one SRAM buffer into 16 bit data in another SRAM buffer. The data bytes can be twinned, as I will be interpolating using the Digital Filter Block later on. I have used DMA to move data from SRAM to Peripheral, and Peripheral to SRAM, but early on my attempts to move from SRAM to SRAM did nothing. I'm sure I will figure it out now, since I *have* to. I would like to do this at as high a speed as possible. I guess I could DMA into a register and then DMA out of a register; however, PSOC only supports 8 bit registers. Any suggestions? Thanks in advance! |
威斯康星州
用CPU移动数据会更快。使用中间位置进行DMA传输,用“PaulLoVin”查看相似的例子 http://www. Cypop.com /评论/ 348136 我相信你可以直接用8位数据来填充过滤器,同时使用过滤器对齐(和一致性)属性来移动比特。检查这个例子 HTTPS://www. Haskist.IO/BMAH/PSOC-5LP-16位和24位数字滤波器-示例-DDCF9C?REF=部分和REFIDID = 19101和偏移= 28 以上来自于百度翻译 以下为原文 wsm, moving data with CPU will be faster. To use intermediate location for DMA transfer look at similar example by "pavloven" http://www.cypress.com/comment/348136#comment-348136 I believe you can feed the Filter directly with 8-bit data, while shifting bit by using Filter Alignment (and Coherency) properties. Check e.g. this example https://www.hackster.io/bmah/psoc-5lp-16-bit-and-24-bit-digital-filter-code-examples-ddcf9c?ref=part&ref_id=19101&offset=28 |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
509浏览 2评论
470浏览 2评论
422浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-2 16:33 , Processed in 1.045511 second(s), Total 75, Slave 59 queries .
