大家好,
我正着手开发我的第一个真正的FPGA PCB。没有更简单的开发板:) 我正在试图弄清楚如何使用带有FPGA的1000BASE-T 1.25 GBd小型可插拔收发器。 我告诉我需要终止FPGA上的LVDS(低电压挖掘.sig)输入。有谁知道哪个FPGA能够做到这一点。还有任何应用笔记终止LVDS到xilinx fpga吗? 谢谢 -麦克风 以上来自于谷歌翻译 以下为原文 Hi All, I"m embarking on my first real FPGA PCB. No more easy dev boards :) I'm trying to figure out how to use 1000BASE-T 1.25 GBd Small Form Pluggable transceiver with an FPGA. I"m told that I need to terminate for LVDS(low voltage dig. sig) input on FPGA. Does anyone know which FPGA's are capable of this. Also are there any app notes on terminating for LVDS into a xilinx fpga? Thanks -mike |
5个回答
您打算使用哪种设备?
通常LVDS信号仅需要接收器端的100欧姆电阻器。 一些FPGA(例如Virtex-5,V6,S6,S3A,S3E ......)具有用于LVDS的片上端接方案,称为DIFF_TERM。 LVDS XAPP: http://www.xilinx.com/support/documentation/anbusinterfaceio_lvds.htm 你打算使用多点LVDS吗? -------------------------------------------------- -------------------------------------------------- --------不要忘记回复,kudo,并接受为解决方案.---------------------------- -------------------------------------------------- --------------------------- 以上来自于谷歌翻译 以下为原文 Which device are you planning to use? Generally LVDS signals only needs and 100-ohm resistor at the receiver end. Some FPGAs (such as Virtex-5, V6, S6, S3A, S3E...) have the on-chip termination scheme for LVDS called DIFF_TERM. LVDS XAPPs: http://www.xilinx.com/support/documentation/anbusinterfaceio_lvds.htm are you going to use multi-drop LVDS? ------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. --------------------------------------------------------------------------------------------------------- |
要以1.25 Gbps运行,您需要使用GTP收发器。
看看ML-505评估 电路板原理图,了解它是如何连接到Virtex 5的SFP的.Spartan 6 LXT应该类似。 HTH, 的Gabor - Gabor 以上来自于谷歌翻译 以下为原文 To run at 1.25 Gbps you need to use a GTP transceiver. Take a look at the ML-505 eval board schematics to see how this is hooked up to an SFP for Virtex 5. Spartan 6 LXT should be similar. HTH, Gabor -- Gabor |
iguo写道:
您打算使用哪种设备? 通常LVDS信号仅需要接收器端的100欧姆电阻器。 一些FPGA(例如Virtex-5,V6,S6,S3A,S3E ......)具有用于LVDS的片上端接方案,称为DIFF_TERM。 LVDS XAPP: http://www.xilinx.com/support/documentation/anbusinterfaceio_lvds.htm 你打算使用多点LVDS吗? 好吧,我把它缩小到了Virtex,因为我读到了一个家庭能够做LVDS的地方。 我不确定多点LVDS是什么。 我做了一个quickGooglesearch并发现“多点LVDS允许许多接收器由一个Virtex-E LVDS驱动器驱动。” 我想这意味着你可以使用LVDS从FPGA传输到多个接收器。 我应该再看一下吗? -麦克风 以上来自于谷歌翻译 以下为原文 iguo wrote: Well I've narrowed it down to Virtex as I read somewhere that family is capable of doing LVDS. I'm not sure what multi-drop LVDS is. I did a quick Google search and found that "Multi-drop LVDS allows many receivers to be driven by one Virtex-E LVDS driver." I guess that means you can transmit from the FPGA using LVDS to multiple receivers. Should I look into this more? -mike |
那取决于你自己的设计。
你打算设计总线接口吗? 如果是这样,你可以看看: http://www.xilinx.com/support/documentation/application_notes/xapp231.pdf http://www.xilinx.com/support/documentation/application_notes/xapp243.pdf -------------------------------------------------- -------------------------------------------------- --------不要忘记回复,kudo,并接受为解决方案.---------------------------- -------------------------------------------------- --------------------------- 以上来自于谷歌翻译 以下为原文 Well it depends on your own design. Are you going to design a bus interface or not? If so, you can take a look at: http://www.xilinx.com/support/documentation/application_notes/xapp231.pdf http://www.xilinx.com/support/documentation/application_notes/xapp243.pdf ------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. --------------------------------------------------------------------------------------------------------- |
wuchy143写道:
iguo写道: 您打算使用哪种设备? 通常LVDS信号仅需要接收器端的100欧姆电阻器。 一些FPGA(例如Virtex-5,V6,S6,S3A,S3E ......)具有用于LVDS的片上端接方案,称为DIFF_TERM。 LVDS XAPP: http://www.xilinx.com/support/documentation/anbusinterfaceio_lvds.htm 你打算使用多点LVDS吗? 好吧,我把它缩小到了Virtex,因为我读到了一个家庭能够做LVDS的地方。 Spartan 3系列FPGA也支持LVDS。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 wuchy143 wrote:Spartan 3-family FPGAs also support LVDS. ----------------------------Yes, I do this for a living. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2452浏览 1评论
660浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 13:29 , Processed in 3.475758 second(s), Total 82, Slave 66 queries .
