扫一扫,分享给好友
嗨,如果你可以帮助我,我会徘徊,或者你知道谁可以帮助我。
我有一个采用XC4010E Xilinx芯片的采集板。 芯片损坏(它上面有两个孔!)。 我需要购买完全相同的芯片才能更换它。 芯片的标签是XC4010E PQ160CMM9921 A1081584A 4C我知道XC4010E和PQ160C的含义,但其余部分对我来说不得而知。 是否足以订购芯片的部件号(XC4010E),封装(PQ),引脚(160)和温度规格(C)? 我真的需要知道“4C”的含义吗? (我见过2C或3C芯片)。 感谢您的时间。 胡安 以上来自于谷歌翻译 以下为原文 Hi, I was wandering if you can help me, or maybe you know who can help me. I have an acquisition board which uses a XC4010E Xilinx chip. The chip is damaged (it has two holes on it!). I need to buy the exactly same chip in order to replace it. The labels of the chip are XC4010E PQ160CMM9921 A1081584A 4C I know the meaning of XC4010E and PQ160C, but the rest is unknown for me. Is enough to order the chip for its part number (XC4010E), package (PQ), pins (160), and temperature specification (C) ? Do I really need to know what the "4C" means? (I have seen chips with 2C or 3C). Thank you for your time. Juan |
胡安,
http://www.xilinx.com/support/documentation/data_sheets/4000.pdf 那些标记是速度等级.... Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Juan, http://www.xilinx.com/support/documentation/data_sheets/4000.pdf Those markings are the speed grade.... Austin Lesea Principal Engineer Xilinx San Jose |
这里描述了顶部零件标记:
http://www.xilinx.com/cn/support/documentation/user_guides/ug112.pdf(Device Package User Guide),第12-15页 干杯, BT 以上来自于谷歌翻译 以下为原文 The top-side part markings are described here: http://www.xilinx.com/support/documentation/user_guides/ug112.pdf (Device Package User Guide), pages 12-15 Cheers, bt
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2453浏览 1评论
660浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 14:58 , Processed in 1.257921 second(s), Total 77, Slave 61 queries .
