嗨,
我正在使用XUPV5-LX110T评估平台在FPGA上实现OpenSparc。 给出的整个项目文件是使用EDK 10.3版本SP3生成的。 但我的实验室安装了12.2版本。 毫无疑问,EDK更新了大多数IP的版本,但许多较旧的IP都不可用。 我陷入困境,因为我无法生成位文件或编程FPGA。 我安装EDK 10.1的努力是徒劳的,因为我被要求提供我一直在联系Xilinx服务的注册ID,他们没有回复。 任何人都可以在12.2版本的EDK中开发项目,以便有意义地实际使用XUPV5吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi , I am using the XUPV5-LX110T Evaluation Platform for the OpenSparc implementation on FPGA. The entire project file given is generated using EDK 10.3 version SP3. But my lab has 12.2 version installed. No doubt, EDK updates the version of most IPs, but many of the older IPs are unavailable. I am stuck as I cannot generate the bit file or program the FPGA. My effort to install EDK 10.1 was futile as I was requested to give the registration ID for which I have been contacting the Xilinx service and they are not replying. Can anybody develop the project in 12.2 version of EDK so that it is possible to actually use the XUPV5 meaningfully? Thanks. |
也许你应该在EDK / Platform Studio论坛上发帖?
你可能会在那里看到更多动作...... - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Maybe you should post this in the EDK/Platform Studio forum? You might see more action there... - Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2445浏览 1评论
658浏览 1评论
520浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-24 02:03 , Processed in 1.206945 second(s), Total 75, Slave 59 queries .
