大家好,
当我将在XPS中为我的系统生成的比特流下载到我的目标板时出现错误.jtag链是串行链,设备1是来自ACTEL的aglp125vs CPLD,设备2是目标FPGA SPARTAN3ADSP3400A.falowing是信息。 -------------------------------------------------- -------------------------------------------------- -------------------------------------------------- -------------------------------------------------- ---------- INFO:iMPACT:583 - '2':从设备读取的idcode与bsdl File.INFO:iMPACT:1578 - '2'中的idcode不匹配:Device IDCODE:00000001110000100111000001001001INFO :iMPACT:1579 - '2':预计IDCODE:00000011100001001110000010010011制作:*** [下载]错误1 我更改了download.cmd,如下所示: setMode -bscansetCable -p autoidentifyaddDevice -p 1 -file etc / aglp125.bsdassignfile -p 1 -file etc / aglp125.bsdassignfile -p 2 -file implementation / download.bitprogram -p 2quit 但是当我用IMPACT下载比特流时,程序就成功了。 当我使用sdk编程fpga时也出现错误。错误显示如下: 程序FPGA failedERROR:无法下载位文件。 有没有人可以帮助我? 谢谢提前! ----------- wangqueping 以上来自于谷歌翻译 以下为原文 hi all, there was a error when i download bitstream which generated for my systerm in XPS to my target board .the jtag chain was a serial chain ,which device 1 was a aglp125vs CPLD from ACTEL and device 2 was the target fpga SPARTAN3ADSP3400A.the falowing was the info. ---------------------------------------------------------------------- ---------------------------------------------------------------------- ---------------------------------------------------------------------- INFO:iMPACT:583 - '2': The idcode read from the device does not match the idcode in the bsdl File. INFO:iMPACT:1578 - '2': Device IDCODE : 00000001110000100111000001001001 INFO:iMPACT:1579 - '2': Expected IDCODE: 00000011100001001110000010010011 make: *** [download] Error 1 I has changed the download.cmd like the following: setMode -bscan setCable -p auto identify addDevice -p 1 -file etc/aglp125.bsd assignfile -p 1 -file etc/aglp125.bsd assignfile -p 2 -file implementation/download.bit program -p 2 quit But when I download bitstream with IMPACT,the program was successed. there was also a error when i use sdk to program fpga .the error was shown like this: Program FPGA failed ERROR: Failed to download the bit file. is there anyone can help me ? thanks advance ! -----------wangqueping |
修改download.cmd如下
setMode -bscansetCable -p autoidentify assignfile -p 1 -file etc / AGLP125V5_CS289.bsd assignfile -p 2 -file implementation / download.bitprogram -p 2quit 名为AGLP125V5_CS289.bsd的文件是从actel websit下载的。 以上来自于谷歌翻译 以下为原文 modify the download.cmd as following setMode -bscan setCable -p auto identify assignfile -p 1 -file etc/AGLP125V5_CS289.bsd assignfile -p 2 -file implementation/download.bit program -p 2 quit the file named AGLP125V5_CS289.bsd was downloaded from the actel websit. |
在大多数情况下,此IDCODE错误消息表示电路板问题。
主要是与JTAG链硬件相关的问题。 所以请检查电路板的所有编程硬件。 执行IDCODE循环测试。 如果IDCODE循环失败,请访问http://www.xilinx.com/support/answers/8902.htm 根据配置指南建议检查所有连接 检查电缆和电缆的连续性。 电缆插入方向。 检查CPLD的所有电压。 它们应符合数据表建议的范围 马赫什 以上来自于谷歌翻译 以下为原文
Mahesh |
2474 浏览 7 评论
2860 浏览 4 评论
2321 浏览 9 评论
3406 浏览 0 评论
2502 浏览 15 评论
2154浏览 1评论
644浏览 1评论
503浏览 1评论
2054浏览 0评论
783浏览 0评论
GMT+8, 2025-2-2 22:14 , Processed in 1.431348 second(s), Total 77, Slave 61 queries .
