我想安装WEBPack 12.1,但是我不能将我需要使用的计算机连接到互联网。
我安装了WEBPack, 我将文件Xilinx.lic从连接到局域网的计算机复制到目标计算机。 我仍然得到一个错误。 有人知道我怎么从这里出发吗? 提前致谢 RDS 以上来自于谷歌翻译 以下为原文 I am tring to install WEBPack 12.1, but the computer that I need to use is not allowed to be connected to to internet. I installed the WEBPack, I copied the file Xilinx.lic from computer that is connected to the lan to the target computer. And I still get an error. Does anybody know how I am to proceed from here? thanks in advance RDS |
5个回答
你发现,这是行不通的。 为什么不为非联网机器创建新许可证? WebPack许可证不收取任何费用。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 >I copied the file Xilinx.lic from computer that is connected to the lan to the target computer. This won't work, as you found out. Why didn't you just create a new license for the non-networked machine? There is no cost for the WebPack license. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.comView solution in original post |
sali***uryr写道:
我想安装WEBPack 12.1,但是我不能将我需要使用的计算机连接到互联网。 我安装了WEBPack, 我将文件Xilinx.lic从连接到局域网的计算机复制到目标计算机。 我仍然得到一个错误。 有人知道我怎么从这里出发吗? 提前致谢 RDS 所以,帮助我们通过详细说明错误来帮助您,而不是让我们猜测。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 sali***uryr wrote:So, help us help you by detailing the error, instead of making us guess. ----------------------------Yes, I do this for a living. |
你发现,这是行不通的。 为什么不为非联网机器创建新许可证? WebPack许可证不收取任何费用。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 >I copied the file Xilinx.lic from computer that is connected to the lan to the target computer. This won't work, as you found out. Why didn't you just create a new license for the non-networked machine? There is no cost for the WebPack license. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2423 浏览 7 评论
2824 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2465 浏览 15 评论
1180浏览 1评论
587浏览 1评论
452浏览 1评论
2005浏览 0评论
731浏览 0评论
GMT+8, 2024-12-24 02:28 , Processed in 1.342888 second(s), Total 86, Slave 69 queries .
