你好,
有没有任何形式可以像累加器那样使用计数器? 我想使用一个计数器,因为它的资源使用率要低得多。 例如,纹波计数器可能有效,但我需要在每个时钟周期有一个可变数量的脉冲,具体取决于要与前一个值相加的数字。 谢谢 以上来自于谷歌翻译 以下为原文 Hello, Is there any form to use a counter like an accumulator?. I want to use a counter because its use of resources are much lower. For example, a ripple counter may work, but I need have, at each clock cycle, a variable number of pulses, depending on the number that is gonna be sum to the previous value. Thank |
由于支持加法的专用逻辑,在计数器和累加器之间的FPGA中没有显着的资源差异。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 There is no significant resource difference in an FPGA between a counter and an accumulator due to the dedicated logic to support addition.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
如果时钟的运行速度比累加器数据速率快N倍,则N为数字
在系统中的位,你可能会考虑位串行算术。 这通常不用于FPGA 除非你用非常大的数字做一些慢的事情并且想要使用移位寄存器 每片获得更多比特。 - Gabor 以上来自于谷歌翻译 以下为原文 If you have a clock running N times faster than the accumulator data rate, where N is the number of bits in the system, you might consider bit-serial arithmetic. This is not typically used in FPGA's unless you're doing something slow with very large numbers and want to use the shift-registers to get more bits per slice. -- Gabor |
2363 浏览 7 评论
2782 浏览 4 评论
2248 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
736浏览 1评论
526浏览 1评论
339浏览 1评论
745浏览 0评论
1943浏览 0评论
GMT+8, 2024-11-10 22:16 , Processed in 0.962925 second(s), Total 46, Slave 41 queries .
