我们有一台Agilent 8714ES网络分析仪,我们需要它的labview驱动程序,请提前感谢您
以上来自于谷歌翻译 以下为原文 We have an Agilent 8714ES network analyzer and we need its LABView driver Thank you in advance |
8714分析仪现有VXI即插即用驱动程序。
该驱动程序可以在LabView中使用。 下面是一个旧的应用笔记,讨论在LabView(主要是旧版本)中使用驱动程序。 对于较新版本的LabView,您可能还需要安装NI提供的仪器驱动程序导入向导,以将驱动程序转换为更新的样式。 871x VXI即插即用驱动程序:[http://www.home.agilent.com/agilent/software.jspx?ckey=2252497&lc=eng&cc=US&nid=-536902655.536881989&id=2252497]如何 将VXI即插即用驱动程序与Agilent VEE,C / C ++,Visual Basic,LabVIEW和LabWindows / CVI(旧)配合使用:[http://cp.literature.agilent.com/litweb/pdf/5988-2790EN.pdf] 以上来自于谷歌翻译 以下为原文 There is an existing VXI Plug and Play Driver for the 8714 analyzer. That driver can be used in LabView. Below is also an old app note that talks about using the driver in LabView (primarily older version). For newer versions of LabView you will probably need to also installed the Instrument Driver Import Wizard available from NI to convert the drivers to the newer style. 871x VXI Plug and Play Driver: [http://www.home.agilent.com/agilent/software.jspx?ckey=2252497&lc=eng&cc=US&nid=-536902655.536881989&id=2252497] How to use VXI Plug and Play Driver with Agilent VEE, C/C++, Visual Basic, LabVIEW, and LabWindows/CVI (old): [http://cp.literature.agilent.com/litweb/pdf/5988-2790EN.pdf] |
yweyerwq 发表于 2019-1-15 08:19 嗨,我需要用于Labview的8714C驱动程序。 我已经部分地完成了odanzy建议的转换方法,不幸的是他们问我.fp文件..我找不到那种文件,因为我甚至无法在我的电脑中安装旧驱动程序(窗口7)。 请帮忙。 以上来自于谷歌翻译 以下为原文 Hi, I need the 8714C driver for Labview. I have partially went through the conversion method that suggested by odanzy, unfortunately they asked me for .fp file..I couldnt find that kind of file because I even couldnt install the old driver in my pc (window 7). Pls help. |
1305 浏览 0 评论
2381 浏览 1 评论
2202 浏览 1 评论
2073 浏览 5 评论
2957 浏览 3 评论
1155浏览 1评论
764浏览 0评论
963浏览 0评论
1305浏览 0评论
GMT+8, 2025-1-1 08:16 , Processed in 1.408860 second(s), Total 48, Slave 41 queries .
