嗨,
我只是想了解一下Flash威廉希尔官方网站 。因为我刚开始,我的问题不是太“专业”,对不起( - : 我知道今天有两种主要的闪存类型:NOR和NAND。参考STM8L,那里使用的Flash类型是什么?由于在STM8中w / r操作看起来相对较快,我猜它利用NAND或MCU的内部FLASH存储器既不是上述类型之一?先谢谢你。 #eeprom#what-does-eeprom-stand-for #memory 以上来自于谷歌翻译 以下为原文 Hi, I'm trying just to learn a bit about the Flash technologies. Since I'm just starting, my question is not too ''professional'', sorry (-:. I know today there are 2 main flash types : NOR and NAND. Referring to STM8L, what is the Flash type used there ? Since the w/r operations look relatively fast in STM8, I guess it utilize NAND or perhaps internal FLASH memory of MCUs is neither one of the mentioned types ? Thank you in advance. #eeprom #what-does-eeprom-stand-for #memory |
4个回答
你好Yevpatoria,其中任何一个。 STM8程序和数据存储器基于EEPROM威廉希尔官方网站
以上来自于谷歌翻译 以下为原文 Hello Yevpator, Any of them. The STM8 programm and data memory is based on EEPROM technology ... |
你好,
但是在数据表和其他文档中,我看到“闪存程序存储器”。闪存不是EEPROM,不是吗?我甚至发现程序手册PM0054名为''如何编程STM8L闪存程序存储器和数据EEPROM'',因此STM8L中的闪存程序存储器和数据EEPROM不一样。谢谢。 以上来自于谷歌翻译 以下为原文 Hello, But in the datasheet and the other documents i see there ''Flash program memory''. Flash is not EEPROM, isn't it ? I even found the Program manual PM0054 named ''How to program STM8L Flash program memory and data EEPROM'',so the Flash program memory and data EEPROM are not the same in STM8L. Thanks. |
''EEPROM''代表
lectrically raseable rogrammable ead- NLY 埃默里。 这个名称没有说明用于实现它的威廉希尔官方网站 (除了它是可电擦除的)。 过去,“EEPROM”用于指代专为非易失性存储而设计的设备 - 而不是代码存储 - 但这是使用而不是威廉希尔官方网站 的区别,而现在,Flash经常被称为作为''EEPROM''...... 以上来自于谷歌翻译 以下为原文 ''EEPROM'' just stands for lectrically raseable rogrammable ead- nly emory. The name says nothing about the technology used to implement it (beyond it being electrically eraseable). It used to be the case that ''EEPROM'' was used to refer to devices specifically designed for non-volatile storage - as opposed to code storage - but that was a distinction of usage rather than technology and, nowadays, Flash often referred to as ''EEPROM''... |
http://en.wikipedia.org/wiki/Flash_memory
以上来自于谷歌翻译 以下为原文 http://en.wikipedia.org/wiki/Flash_memory |
2904 浏览 1 评论
3286 浏览 1 评论
1868 浏览 1 评论
3721 浏览 6 评论
6132 浏览 21 评论
GMT+8, 2025-3-8 13:15 , Processed in 0.563795 second(s), Total 53, Slave 47 queries .
