嗨,
我正在使用双MB目标V5 ml507参考XAPP996教程,其中我们为每个MB使用2个PLB总线,但PLB总线是多重总线,所以为什么我们不为这两个处理器使用一个PLB总线 ?? 另外,我们可以使用FSL总线制作多处理器架构,那么两种架构之间有什么区别(使用带有2个plb总线的双MB和使用带FSL总线的多处理器)? 如果有任何想法,请帮助我! INES 以上来自于谷歌翻译 以下为原文 Hi, I'm working with dual MB targeting V5 ml507 by referencing to the XAPP996 tutorial, in which we used 2 PLB bus for each MB, but PLB bus is a multimaitre bus, so why we don't use one PLB bus for both of processors?? also, we can make a multiprocessor architecture using FSL bus, so what the difference between the two architectures ( using dual MB with 2 plb bus and using multiprocessor with FSL bus)? Please if any one have any idea, please help me! INES |
需要两个PLB,因为在同一个PLB总线上不能有两个主机。
鉴于PLB上的典型必要外设(定时器,块内存等),创建仅具有FSL总线的多处理器系统是不可行的。 此外,FSL是点对点通信。 我可以看到使用两个FSL连接进行高吞吐量的处理器间通信。 在大多数情况下,互斥锁和/或邮箱绰绰有余。 以上来自于谷歌翻译 以下为原文 Two PLBs are necessary because you cannot have two masters on the same PLB bus. Given the typical necessary peripherals on the PLB (timers, block ram, etc), creating a multiprocessor system with only an FSL bus is infeasible. Additionally, FSL is point-to-point communication. I could see using two FSL connection for high-throughput inter-processor communication though. In most cases, a mutex and or mailbox is more than sufficient. |
嗨,
我很担心PLB总线是多主机,这就是为什么我问这个问题! 因此,由于PLB总线是多主机,为什么我们不在相同的PLB总线上使用两个MicroBlaze处理器。 谢谢, INES 以上来自于谷歌翻译 以下为原文 Hi, I'm fraid that PLB bus is multimaster, is why I asked this question!! so, since PLB bus is multimaster why we don't use the tow MicroBlaze processors on the same PLB bus. Thank you, INES |
2694 浏览 7 评论
3013 浏览 4 评论
2433 浏览 9 评论
3539 浏览 0 评论
2636 浏览 15 评论
3420浏览 1评论
835浏览 1评论
697浏览 1评论
GMT+8, 2025-7-6 04:07 , Processed in 1.266110 second(s), Total 48, Slave 42 queries .
