我想通过拆焊板上的插头插头并用插座替换它来使电路板更有用,我可以将电线直接插入。
我尝试过使用编织物和焊锡吸盘,但两者都没有有效工作。有没有人有任何建议去除这些插头?或者我最好使用套接字和标题等等? 以上来自于谷歌翻译 以下为原文I'd like to make the board more useful by desoldering the header plugs on the board and replacing them with sockets I can plug wires directly into. I've tried using braid and my solder sucker but neither is working effectively. Does anyone have any advice for removing these plugs ? Or am I better off using sockets and headers and so on ? |
3个回答
保罗,
首先尝试在连接处使用少量焊料,焊料中的助焊剂通常比廉价脱焊芯上的助焊剂更好,焊料的熔点也可能低于电路板。然后使用你的焊料拉拔器。 就个人而言,我会离开董事会并使用女性跳线,例如Schmartboard制造的跳线。 约翰 以上来自于谷歌 以下为原文Paul, Try using a little solder on the connections first, The flux in your solder is often better than the flux on cheap desoldering wicks, also your solder will likely have a lower melting point than the boards. then use your solder puller. Personally, I'd leave the board along and use female jumpers, such as those made by Schmartboard. John |
谢谢 - 我会把那些连接器看起来
保罗,
就我个人而言,我拆开了由铜侧的女性替换的2x6男性标题。 用一点铁和一个泵没问题 通过这种方式,电路板可以插在扩展板上,我可以访问所有IO引脚。 罗曼 以上来自于谷歌翻译 以下为原文Paul, Personally, I unsolder the 2x6 male header that I replaced by females on the copper side. No trouble for it with a little iron and a pump In this way, the board can be plug over an extension and i can access to all IO pin. romain |
2821 浏览 1 评论
3262 浏览 1 评论
1838 浏览 1 评论
3687 浏览 6 评论
6091 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
391浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
481浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
312浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
228浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
333浏览 2评论
GMT+8, 2025-2-1 04:43 , Processed in 1.016507 second(s), Total 50, Slave 44 queries .
