亲爱的先生,
现在我想删除使用st7MC在开环模式下进行无传感器控制的预定位阶段,我可以这样做吗?因为你知道,在预置位阶段,电机可能会在启动时反向运动。谢谢你的帮助! mcuintereest 以上来自于谷歌翻译 以下为原文 Dear sir, Now I want to delete the prepositioning phase whilse using st7MC for sensorless control in open loop mode, Can I do like that? becasue you know, with prepositiong phase the motor maybe move reversely in the start-up. Thanks the help! mcuintereest |
亲爱的先生,
前置阶段对于在无传感器系统中实现最佳电机启动至关重要。 理论上,如果你消除了这个阶段,你可能在任何情况下都会出现反向旋转,这是由于一个不为人知的转子位置,甚至最糟糕的是,你可能在所有电机启动失败,导致突然转子 - 阻塞的情况。 所以,在我看来你应该保持对齐阶段...... 问候, Tanio 以上来自于谷歌翻译 以下为原文 Dear sir, the prepos phase is essential to have the best motor start-up in a sensorless system. If, theoretically, you eliminated this stage, you could have in any case a reverse rotation, due to a not well-known rotor position, and, even worst, you could fail at all the motor start-up, causing a sudden rotor-blocked condition. So, in my opinion you should kept the alignment phase... Regards, Tanio |
2413 浏览 1 评论
3129 浏览 1 评论
1698 浏览 1 评论
3511 浏览 6 评论
5867 浏览 21 评论
857浏览 4评论
1232浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
501浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1214浏览 3评论
1269浏览 3评论
GMT+8, 2024-9-20 23:48 , Processed in 0.900862 second(s), Total 45, Slave 40 queries .
