我想我知道答案,但我只是想验证。我在我们的产品中有几个不同的处理器,我目前在Ubuntu Linux上使用Eclipse和GDB服务器进行其他开发设置。我想将Eclipse与Cosmic编译器(或Raisonance编译器)和GDB服务器一起用于在同一Linux主机上进行调试。我已经看到了如何在Eclipse中使用Cosmic编译器的注释,但是我没有看到验证编译器是在Linux下运行还是GDB服务器知道如何与ST-Link JTAG仿真器通信。有没有人有答案?
谢谢, 布赖恩 以上来自于谷歌翻译 以下为原文 I think I know the answer to this, but I just wanted to verify. I have several different processors which we have in our products, and I am currently using Eclipse with GDB server on Ubuntu Linux for every other development setup. I would like to use Eclipse with the Cosmic compiler (or Raisonance compiler) and GDB server for debugging on the same Linux host. I have seen notes on how to use the Cosmic compiler with Eclipse, but I haven't seen verification as to whether the compiler runs under Linux or whether GDB server knows how to talk to the ST-Link JTAG emulator. Does anyone have an answer? Thanks, Bryan |
你好,
>> ..但我还没有看到验证编译器是否在Linux下运行.. 我们的所有编译器都有Linux版本,但Linux下没有免费软件包。至于调试器,我们的(Cosmic)没有移植到Linux下:至于其他调试器,我不知道。 问候, 卢卡(宇宙) 以上来自于谷歌翻译 以下为原文 Hello, >> ..but I haven't seen verification as to whether the compiler runs under Linux.. we do have Linux versions of all our compilers, but there's no free package available under Linux. As for the debugger, ours (Cosmic) is not ported under Linux: as for other debuggers, I would not know. Regards, Luca (Cosmic) |
2779 浏览 1 评论
3251 浏览 1 评论
1824 浏览 1 评论
3667 浏览 6 评论
6062 浏览 21 评论
1347浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
373浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
467浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
292浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
214浏览 2评论
GMT+8, 2025-1-11 12:13 , Processed in 1.037001 second(s), Total 44, Slave 39 queries .
