我想知道,HTTPNET服务器是否可以监听端口80来输入连接,然后将它们重定向到端口443?我的应用程序有一个HTTPS服务器,但是人们经常忘记在HTTPS中键入://在IP地址之前。在V2.03中有一种方法,在端口80上有一个简单的侦听器,它可以将流量重定向到端口443。我认为它可以实现,但我问它是否支持和谐。
以上来自于百度翻译 以下为原文 I am wondering, is it possible for the http_net server to listen to port 80 for incoming connections, and then redirect them to port 443? My application has an https server, but people frequently forget to type in thet https:// before the IP address. Is there a way, in HARMony v2.03, to have a simple listener on port 80 that would redirect the traffic to port 443? I figure it can be implemented, but I am asking if it is supported in Harmony. |
4个回答
类似这样的MayBeHTTPS://DeaveID.Mozilla…/Web/HTTP/重定向
以上来自于百度翻译 以下为原文 something like this maybe https://developer.mozilla.../Web/HTTP/Redirections |
这是一个基本的想法,但是问题是如何在端口80上实现一个小的侦听器来执行这些重定向。Ed,抱歉延迟了,我从那时起就一直没有工作。如果你感兴趣的话,我想我会通知这个帖子,如果我曾经成功,但是,这不是我的当务之急。
以上来自于百度翻译 以下为原文 This is the basic idea, however, the question is how to implement a small listener on port 80 to perform these redirects. Ed, sorry about the delay, I haven't been working on it since. If it is of interest to you, be asured that I will notify this thread if I ever succeed, however, this is not my top priority at the moment. |
《超级星号》,不用担心,我自己还没有积极地做这件事。谢谢吉姆的想法。我试图通过在协调中添加第二个NETSIPReS实例(V2.04)来实现它,但是我没有看到在哪里可以指定第二个监听端口。我不认为这是正确的方法。
以上来自于百度翻译 以下为原文 @suprastar, no worries I haven't been actively working on this myself. Thanks Jim for the idea. I tried to implement it by adding a second NET_PRES instance in harmony (v2.04), but I didn't see where I could specify a second listening port. I don't think this was the right approach. Ed |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
486浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-21 02:34 , Processed in 1.354754 second(s), Total 53, Slave 46 queries .
