电子发烧友论坛|
大家好,
我用CY8CKIT-042-BLUKIT做我的广播设备。我已经把我的固件放在CyPress的例子中“动态广播”(例子9),如果我通过GELE和GESMART检查BLE传输,所有的运行都很好。问题是,我意识到,无论是在iOS、Android(4.2和5.1)还是Windows Phone 8.1上,我都看不到任何智能手机上的BLE设备。 我想的问题是我的代码,我直接测试柏实例8(“恒台”)和9(“dynamicbroadcaster”)但结果都是一样的:我发现BLE设备cysmartbut不会发生如果我搜索与智能手机或笔记本电脑与BLE。 我已经修改了广告的时间间隔是否有一些改进,但我没有看到anyupgrade。 有人能帮我吗? 如果需要更多的信息,随便问吧。 提前谢谢你的时间。 约书亚 以上来自于百度翻译 以下为原文 Hi to all, I am using a CY8CKIT-042-BLE kit to do my broadcaster device. I have based my firmware on the Cypress example "Dynamic Broadcaster" (example 9) and all is running fine if I check the BLE transmissions through the dongle and CySmart. The problem is that I have realized that I can't see my BLE device on any smartphone both with iOS, Android (4.2 and 5.1) or Windows Phone 8.1. As I thought the problem was on my code, I have tested directly the Cypress examples 8 ("Constant broadcaster") and 9 ("Dynamic Broadcaster") but the results are the same: I find the BLE device on CySmart but it doesn't happens if I search with an smartphone or even with a laptop with BLE. I have modified the advertising intervals to see if there are some improvement, but I didn't saw any upgrade. Could someone help me? If more information is needed, feel free to ask for it. In advance, thank you for your time. Josué |
3个回答
你好,
您可以在更新所有组件并使用CyScript的最新版本之后测试这个项目。PFA具有更新组件的项目。我查看了CyScript的最新版本,可以看到这个设备。(1.1.1.68)(HTTPS://Pr.GoGoLe.COM/Sture/Apps/详细信息)ID= COM.CyPress CysMaS&HL= EN) 动态广播 4兆字节 以上来自于百度翻译 以下为原文 Hi, Can you test this project after updating all the components and with the latest version of CySmart. PFA the project with updated components. I checked in the latest version of CySmart and could see the device. (1.1.1.68) (https://play.google.com/store/apps/details?id=com.cypress.cysmart&hl=en) |
你好,BMAH,
谢谢你的回复。我试图检查项目的重视,但一个错误出现在PSoC Creator 3.3。问题是,在PSoC Creator 3.3 BLE模块版本不可用。你使用BLE模块2.30版,但我只可以使用版本V2.20。 你可以找到一个附加的截图,我看我的PSoC Creator 3.3在Windows 8.1上运行。 你可以告诉我如何更新BLE模块版本2? 提前,非常感谢你, 约书亚 模块故障 351.5 K 以上来自于百度翻译 以下为原文 Hi BMAH, Thank you for your response. I have tried to check the project attached, but an error has appeared on PSoC Creator 3.3. The problem is that the BLE module version is not available on PSoC Creator 3.3. You have used the BLE module version 2.30 but I only can use version v2.20. Attached you can find an screenshot of what I'm seeing on my PSoC Creator 3.3 running on Windows 8.1. Could you tell me how can I update the BLE module to version 2.30? In advance, thank you so much, Josué
BLE组件可与Calgor组件包1一起使用。它没有出现在更新管理器中,但是可以手动下载。
以上来自于百度翻译 以下为原文 BLE component is available with Creator Component Pack 1. It did not show up in the update manager, but can be downloaded manually. |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3672 浏览 1 评论
1788 浏览 6 评论
1536 浏览 1 评论
572浏览 2评论
424浏览 2评论
438浏览 2评论
386浏览 2评论
916浏览 2评论
GMT+8, 2024-12-25 21:24 , Processed in 1.047276 second(s), Total 79, Slave 63 queries .
