6个回答
PFS是正满量程;NFS是负满量程。
上楼正解,之前用过这个芯片,性能还不错。
其中要注意上电复位信号的处理,复位不正常,是不输出转换值的。
RESET,我是用个RC电路来完成上电后的延迟复位。 |
PFS:
Positive Full-Scale Error The deviation of the actual last code transition from the ideal last code transition (such as 10 V − 1½ LSB (9.99954) or 5 V − 1½ LSB (4.99977)) after bipolar zero code error is adjusted out. The positive full-scale error includes the contribution from the internal reference buffer. NFS: Negative Full-Scale Error The deviation of the first code transition from the ideal first code transition (such as −10 V + ½ LSB (−9.99984) or −5 V + ½ LSB (−4.99992)) after the bipolar zero code error is adjusted out. The negative full-scale error includes the contribution from the internal reference buffer. |
2300个成员聚集在这个小组
加入小组1149 浏览 2 评论
1507 浏览 2 评论
2025 浏览 1 评论
4342 浏览 2 评论
9172 浏览 1 评论
1892浏览 3评论
1785浏览 2评论
1149浏览 2评论
1794浏览 2评论
1507浏览 2评论
GMT+8, 2025-3-7 06:56 , Processed in 1.083223 second(s), Total 86, Slave 71 queries .
