我正在使用状态机和组件编写程序。
我有一个错误,我不明白。 这是:错误:HDLParsers:164 - “C:/ Documents and Settings / ex1 / project / main_project.vhd”第104行。解析错误,意外PORT,期待OPENPAR或TICK或LSQBRACK。 你能帮我解释一下吗? 以上来自于谷歌翻译 以下为原文 I am writing a program using state machine and component. I have an error and i do not understand. This is : ERROR:HDLParsers:164 - "C:/Documents and Settings/ex1/project/main_project.vhd" Line 104. parse error, unexpected PORT, expecting OPENPAR or TICK or LSQBRACK. Could you explain for me ? |
当您遇到简单的语法错误时,通常会发生这种非常有启发性的消息
比如遗漏分号或忘记关闭括号。 错误是 在上面提到的(104)行或更可能在前一行。 如果你张贴一下你的 代码有人可能会进一步提供帮助。 消息本身表示找到PORT关键字 期望左括号,撇号或左方括号字符“(”,“'”或“[” 问候, 的Gabor - Gabor 以上来自于谷歌翻译 以下为原文 This very illuminating message usually occurs when you have a simple syntax error like leaving out a semicolon or forgetting to close a parenthesis. The error is either in the line mentioned (104) or more likely on the preceding line. If you post a bit of your code someone might be able to help further. The message itself indicates that the PORT keyword was found when it was expecting a left parenthesis, apostrophe, or left square bracket character "(", "'" or "[" regards, Gabor -- Gabor |
我还建议您将项目移动到路径中没有空格的目录。
这不是一个正式的答案,而是我很久以前在这里工作之前开始的一种做法,并且已经证明了很多次证明是有益的。 他们试图正确地逃避这些(一个空间传统上是工具争论的命令行分隔符),但是有很多工具和使用模型。 可能仍然存在一些可能导致问题的极端情况。 只是一个友好的非正式建议...... BT 以上来自于谷歌翻译 以下为原文 I would also recommend you move your project to a directory with no spaces in the path. Not an official answer, but a practice I started a long time ago before I worked here and have seen prove beneficial many times. They've tried to escape these properly (a space is traditionally a command line separator for the tool arguement), but there are a lot of tools and usage models. There are likely still a few corner cases where this can cause issues. Just a friendly unofficial suggestion... bt
2702 浏览 7 评论
3018 浏览 4 评论
2437 浏览 9 评论
3553 浏览 0 评论
2639 浏览 15 评论
3432浏览 1评论
843浏览 1评论
703浏览 1评论
GMT+8, 2025-7-13 18:27 , Processed in 1.193155 second(s), Total 77, Slave 61 queries .
