SPC560B40x如何让程序员参考或者他们称之为这些芯片的长形文档。这不是power arch手册,而是如何使用CAN控制器ADC等?
以上来自于谷歌翻译 以下为原文 SPC560B40x how to get the programmers reference or what ever they call the long form documentation for these chips. This is not the power arch manual but the how to use the CAN controller ADC ect? |
3个回答
你好 ,
您可以使用与您的设备关联的RM, http://www.st.com/content/ccc/resource/technical/document/reference_manual/cf/ad/d5/76/55/1f/49/de/CD00192452.pdf/files/CD00192452.pdf/jcr:内容/翻译/ en.CD00192452.pdf 无论如何,在SPC5Studio工具中,有一些测试应用示例(RLA& HAL) 你可以导入它们。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello , You can use the RM associated to your device, http://www.st.com/content/ccc/resource/technical/document/reference_manual/cf/ad/d5/76/55/1f/49/de/CD00192452.pdf/files/CD00192452.pdf/jcr:content/translations/en.CD00192452.pdf Anyway , in SPC5Studio tool , there is some Test Application example (RLA & HAL) you can import them. Best regards Erwan |
谢谢。
我们仍处于组件选择阶段,尚未使用您的 您的顶级营销网站将CAN总线描述为CAN-FD (更高的传输速率和64字节数据)这是必不可少的 我们的设计似乎只有上面手册中描述的Flex-CAN模块 支持具有8字节数据缓冲区限制的CAN 2.0B。我错过了什么 或者是错误的网站。您的任何处理器都支持CAN-FD吗? 2017年5月3日星期三凌晨2:33,Erwan Y< st-microelectronics@jiveon.com> 以上来自于谷歌翻译 以下为原文 Thank you. We are still in the component selection phase and are not yet using your studio.. Your top level marketing website described the CAN buses as CAN-FD (Higher transmission rates and 64 byte data possible) which is essential to our design yet the Flex-CAN module described in the above manual only seems to support CAN 2.0B with 8 byte data buffer limits. Am I missing something or is the website in error. Do any of your processors support CAN-FD? On Wed, May 3, 2017 at 2:33 AM, Erwan Y |
你好威廉,
对于CAN-FD(64位),您应该切换到SPC58系列。 http://www.st.com/en/automotive-microcontrollers/spc5-mcus-for-interior-networking-and-low-power-applications.html?querycriteria=productId=SS1578 请查看SPC58 http://www.st.com 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello William , For CAN-FD (64 Bits), you should switch into SPC58 Family. http://www.st.com/en/automotive-microcontrollers/spc5-mcus-for-interior-networking-and-low-power-applications.html?querycriteria=productId=SS1578 Please a look in SPC58 on http://www.st.com Best Regards Erwan |
2841 浏览 1 评论
3274 浏览 1 评论
1852 浏览 1 评论
3698 浏览 6 评论
6111 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
401浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
493浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
322浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
240浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
344浏览 2评论
GMT+8, 2025-2-9 10:07 , Processed in 0.914148 second(s), Total 46, Slave 41 queries .
