嗨,我已经把我的未连接的引脚通过电阻连接到接地。现在我想把这些引脚中的一个配置为SCK。可以把这个引脚连接到PIC微控制器的另一个引脚吗?IAM使用144引脚PIC32 MZEF。这两个引脚都是PPS(外围引脚选择)。
以上来自于百度翻译 以下为原文 Hi, I have connected my unconnected pins to ground through resistors.Now i want to configure one of these pins as SCK. Is it possible to connect this pin internally to another pin of the pic microcontroller ?? Iam using 144 pin Pic32mzef. Both pins are PPS.(Peripheral pin select.) |
真的。但所有的SCK引脚是PPS的能力。如果通过PPS,外围输入映射到输出SCK引脚,我会认为外围设备将输入引脚电平。类似地,如果SCK引脚是一个输入,我会认为映射到这个引脚的任何输出外设都会驱动SCK输入。我说的是没有这个设备家族的经验-只是看数据表-所以我对此没有信心。但至少通过数据表快速查看似乎意味着一个合理的成功机会。
以上来自于百度翻译 以下为原文 True. But all the SCK pins are PPS capable. If, via PPS, a peripheral input is mapped to an output SCK pin, I would think the peripheral would input the pin level. Similarly, if an SCK pin is an input, I would think any output peripheral mapped to this pin would drive the SCK input. I'm speaking with no experience with this device family - just looking at the datasheet - so I have no confidence in this. But at least a quick look through the datasheet seems to imply a reasonable chance of success. |
5250 浏览 9 评论
2037 浏览 8 评论
1958 浏览 10 评论
3218 浏览 3 评论
2266 浏览 5 评论
788浏览 1评论
680浏览 1评论
609浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-28 18:54 , Processed in 1.178990 second(s), Total 47, Slave 41 queries .
