嗨,我想控制开发的燃烧器,请告知我,这板附近matchmy要求。!
我想控制的压力和温度传感器和3台燃烧器火焰燃烧器的工作上。一:系统启动(控制:监控传感器的压力和温度):预热塞12v 17a(控制:打开/关闭定时器+温度传感器):风机12v 11a,(控制:开/关+ PWM调速+温度传感器:燃油泵12V,4A,PWM开关(控制:开/关+可变速度开关D +温度传感器燃烧器系统启动时所需的压力和温度将达到的水平。1st辉光插头会在产生火焰,2nd鼓风机将在低流量,3rd燃油泵将用于产生连续的火焰,一:单片机32bit Cortex M4 200mhz 2:闪存2mb +加速器三:内存512四:2u*** +2五:以太网IEEE1588六:ADC 8 7:开/关六mofsets功率:温度传感器6 9:P压力传感器6 10:JTAG头11:TFT控制器+液晶10:I / O 20 11:多功能报警4个+ RTC 12:PWM 8 等待您的帮助答复。问候安德烈·萨米 以上来自于百度翻译 以下为原文 Hi, I want to develop control unit for burner, kindly advise me, which board kit is near to match my requirements .! I want to control burner flame with pressure and temperature sensors and three units are attached with burner working. 1: System start up with ( control : Monitor pressure and Temp by sensors ) 2: Glow Plug 12v 17A (control : switch on/off with timer + Temp sensor ) 3: Blower fan 12V 11A, ( Control : switch on/off + PWM variable speed + temp sensor 4: Fuel Pump 12V, 4A, PWM ( Control : Switch on/off + variable speed + temp sensor Burner system will start up when Pressure and Temp will reached at desired level. 1st glow plug will on for produce flame , 2nd blower will on with low flow, 3rd fuel pump will on for produce continuous flame, 1: MCU 32Bit Cortex M4 200Mhz 2: Flash 2mb + Accelerator 3: Ram 512 4: 2USB + 2 CAN 5: Ethernet IEEE 1588 6: ADC 8 7: Power on/off 6 Mofsets 8: Temperature Sensor 6 9: Pressure Sensor 6 10: Jtag header 11: TFT controller + LCD 10: I/O 20 11: Multi Function AlARMs 4 +RTC 12: PWM 8 Awaiting your helpful reply. Regards Sami |
在同一个问题上到处张贴论坛真的是一个坏习惯!
鲍勃 以上来自于百度翻译 以下为原文 Spamming the forum with the same question all over is really a bad habit! Bob |
目前,PSoC没有以太网IEEE 1588的支持。
以上来自于百度翻译 以下为原文 Presently ,PSoC has no Ethernet IEEE 1588 support |
760个成员聚集在这个小组
加入小组2156 浏览 1 评论
1904 浏览 1 评论
3726 浏览 1 评论
1837 浏览 6 评论
1582 浏览 1 评论
791浏览 2评论
549浏览 2评论
489浏览 2评论
448浏览 2评论
1276浏览 2评论
GMT+8, 2025-3-7 08:16 , Processed in 1.133238 second(s), Total 78, Slave 62 queries .
