6678手册上说能支持最大8G空间,设置XMPAXL1切换,cpu能够访问其余DDR3空间,
但是使用EDMA读写,不论和空间怎么映射,只能度写DDR3最低2G空间, 请教一下,EDMA能不能访问其余DDR3空间,如果能访问要设置那些寄存器 |
5 个讨论
你使用的是XMC的地址映射,如果需要EDMA访问高位地址,你需要使用MSMC的MPAX,详见下述说明。
We have two different types of MPAX. One is located in the C66x core and explained in the section 7.3 XMC Memory Protection and Address eXtension (MPAX) of SPRUGW0B (http://www.ti.com/lit/ug/sprugw0b/sprugw0b.pdf). On the other hand, when EDMA access the memory, it pass a different MPAX and it is explained in the section 2.2 Memory Protection and Address Extension (MPAX) of SPRUGW7A (http://www.ti.com/lit/ug/sprugw7a/sprugw7a.pdf). The following presentation material is also helpful to understand them.
hdfsf 发表于 2019-1-10 10:27 谢谢!已经能访问了 |
hdfsf 发表于 2019-1-10 10:27 你好,请问DMA访问其余DDR3时,应该怎么设置寄存器,我设置之后只有核0可以访问,不知道是什么原因 |
600 浏览 1 评论
447 浏览 1 评论
634 浏览 2 评论
938 浏览 3 评论
716 浏览 1 评论
213浏览 29评论
1176浏览 23评论
336浏览 20评论
301浏览 14评论
156浏览 13评论
GMT+8, 2025-2-12 17:06 , Processed in 0.899881 second(s), Total 49, Slave 43 queries .
