嗨,
我有几块带有Spartan 3器件的电路板,并希望将相同的比特流加载到所有电路板中。 我应该选择哪个端口 在电路板和设备上使用? 是否可以在JTAG配置模式下进行配置? 谢谢。 阿卜杜拉 以上来自于谷歌翻译 以下为原文 Hi, I have a couple of boards with Spartan 3 device and want to load the same bitstream into all of them. Which ports should I use on the board and the device? Is it possible to be able to configure in JTAG Configuration Mode? Thank you. abdullah |
如果您希望将相同的配置比特流加载到多个FPGA中,那么最好的方法可能是通过“宽边”配置的“Ganged”。
您可以在UG332,Spartan-3系列配置用户指南中了解更多相关信息:http://www.xilinx.com/support/documentation/user_guides/ug332.pdf -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 If you wish to load the same configuration bitstream into multiple FPGAs, then the best way of doing this is probably through "Ganged" of "Broad-Side" configuration. You can learn more about this in UG332, the Spartan-3 Family Config User Guide: http://www.xilinx.com/support/documentation/user_guides/ug332.pdf ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
您可以在UG332,Spartan-3系列配置用户指南中了解更多相关信息:http://www.xilinx.com/support/documentation/user_guides/ug332.pdf -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 If you wish to load the same configuration bitstream into multiple FPGAs, then the best way of doing this is probably through "Ganged" of "Broad-Side" configuration. You can learn more about this in UG332, the Spartan-3 Family Config User Guide: http://www.xilinx.com/support/documentation/user_guides/ug332.pdf ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3415 浏览 0 评论
2506 浏览 15 评论
2314浏览 1评论
649浏览 1评论
514浏览 1评论
2062浏览 0评论
790浏览 0评论
GMT+8, 2025-2-12 12:21 , Processed in 1.084405 second(s), Total 77, Slave 61 queries .
