我已经生成了一个正弦和余弦查找表。
有人告诉我,正弦和余弦输出将采用二进制补码格式。 sin / cosine的答案将采用十进制格式。假(sin)(以弧度表示)= -0.9165。 转换后的价值是多少? 是11101110000110011.如果没有,任何机构都可以解释这个过程 谢谢 以上来自于谷歌翻译 以下为原文 i have generated a sine and cosine look up table. it has been told that the the sine and cosine out put will be in the two's complement format. the answers of sin/cosine will be in decimal format.suppose sin(42)(in radians)= -0.9165. what is the converted value of that? is it 11101110000110011. if not can any body explain the process thank you |
嗨!
我过去使用过DDS ROM查找表来生成波形,发现以下两个文件非常有用: http://www.xilinx.com/support/documentation/ip_documentation/dds.pdf和: http://www.ele.uri.edu/courses/ele205/Application-notes/AN1771.pdf 希望这些对您也有用。 干杯! 以上来自于谷歌翻译 以下为原文 Hi! I have used DDS ROM lookup tables for waveform generation in the past and found the following two documents extremely useful: http://www.xilinx.com/support/documentation/ip_documentation/dds.pdf and: http://www.ele.uri.edu/courses/ele205/Application-notes/AN1771.pdf Hopefully these can be of use to you too. Cheers! |
2501 浏览 7 评论
2871 浏览 4 评论
2330 浏览 9 评论
3424 浏览 0 评论
2512 浏览 15 评论
2469浏览 1评论
662浏览 1评论
524浏览 1评论
802浏览 0评论
GMT+8, 2025-2-25 13:16 , Processed in 1.380896 second(s), Total 77, Slave 61 queries .
