嗨,我想知道E4360是可以在外部还是内部编程,因此SAS曲线参数可以连续变化。
我需要它来模拟太阳能电池板(固定)的功率变化24小时循环。 感谢您对此有所了解。 以上来自于谷歌翻译 以下为原文 Hi, I would like to know if E4360 can be programmed externally or internally, so that the SAS curve parameters can vary continuously . I need it to simulate the power variation from a solar panel (fixed) for a 24 hrs cycle. Thank you for spending your thoughts on this. |
嗨,我们确实有一些我们称之为LIST模式的东西,您可以在其中设置SAS参数列表和停留在每个参数的停留时间。
以下是最小步长的信息:256点表最小可编程停留时间= 0.03秒4096点表最小可编程停留时间= 0.35秒程序员的参考也有关于LIST模式的一些信息。 如果这是您正在寻找的,请告诉我。 以上来自于谷歌翻译 以下为原文 Hi, We do have something that we call LIST mode where you can set up a list of your SAS parameters and a dwell time to stay at each of those parameters. Here is the info on the minimum step size: 256-point tables Minimum programmable dwell time = 0.03 seconds 4096-point tables Minimum programmable dwell time = 0.35 seconds The programmer's reference has some info on LIST mode as well. Let me know if this is what you are looking for. |
1408 浏览 0 评论
2425 浏览 1 评论
2280 浏览 1 评论
2118 浏览 5 评论
3036 浏览 3 评论
1514浏览 1评论
847浏览 0评论
1278浏览 0评论
1408浏览 0评论
GMT+8, 2025-3-10 20:48 , Processed in 1.210927 second(s), Total 75, Slave 59 queries .
