编码威廉希尔官方网站
需要改变吗?我是新的18F使用XC8在XIDE。以前我在MPLAB IDE中使用了HTC,用于PIC16F87A。如果需要在编码中改变什么,告诉我它是什么?并建议我在网站上为PIC18F提供源代码示例。谢谢…
以上来自于百度翻译 以下为原文 Is coding techniques need to be alter? I'm new to 18F using XC8 in XIDE. Previously i have used HTC in MPLAB IDE for PIC16F877A. If anything need to be changed in coding tell me what it is? And suggest me the site for source code examples in c for PIC18F. Thank you... |
这是关于第十个基本上同一个问题的话题。IDE对你的代码没有太大的影响,它在MPLAB8和MPLABX中非常相似,只是MPLABX在编辑器中有更多的铃声和哨子,并且通常比MPLA8xC8慢一些,基本上只是稍后的修订。Microchip的N买了HiTeCH并改名为编译器。许多相同的领先程序员仍然参与它的开发。XC8中最新的变化之一是它不再包含PIC18外围库,但是如果你一直使用PIC16F,那么这与你无关。如果你使用的是PIC18F芯片,那么微芯片。希望你用MCC来生成示例代码。你想要什么样的例子?为了使用更简单的外设(USAT,SPI,ADC),你最好学习你的设备的数据表,编写你自己的代码。它只需要USB和以太网,你需要使用其他人编写的代码块。
以上来自于百度翻译 以下为原文 This is about the tenth topic you have started about essentially the same issue. The IDE doesn't have much effect on your code, it's pretty similar in MPLAB8 and MPLABX, just MPLABX has more bells and whistles in the editor, and generally runs slower than MPLAB8 XC8 is essentially just a later revision of HiTech C. Microchip bought HiTech and renamed the compiler. Many of the same lead programmers are still involved in its development. One of the biggest recent changes in XC8 is that it no longer includes the PIC18 peripheral libraries, but if you've been using PIC16F, then that doesn't concern you anyway. If you are using a recent PIC18F chip, then Microchip want you to use MCC to generate example code. What examples do you want? To use the simpler peripherals (USART, SPI, ADC), you're better off studying the datasheet for your device, and writing your own code. It's really only USB and Ethernet that you need to use chunks of code written by other people. |
5425 浏览 9 评论
2125 浏览 8 评论
2041 浏览 10 评论
3294 浏览 3 评论
2338 浏览 5 评论
930浏览 1评论
797浏览 1评论
750浏览 1评论
805浏览 0评论
692浏览 0评论
GMT+8, 2025-4-5 22:10 , Processed in 1.240844 second(s), Total 80, Slave 62 queries .
