嗨,
Spartan 3AN拥有自己的启动闪存,超出了引导所需的大小,也许可以将其用于非易失性存储。 有一个很好的综合 Eielrt 以上来自于谷歌翻译 以下为原文 Hi, the Spartan 3AN has it's own boot flash, which exceeds the size needed for booting purposes, and maybe it's possible to use that for nonvolatile storage. Have a nice synthesis Eielrt |
所有Xilinx FPGA都基于CCL(CMOS配置锁存器) - 它们像SRAM一样易失。
Spartan-3AN是一款Spartan-3A芯片,采用闪存配置器件堆叠在同一封装中...... http://www.xilinx.com/cn/support/documentation/user_guides/ug333.pdf(Spartan-3AN在系统Flash用户指南)http://www.xilinx.com/support/documentation/application_notes/xapp1034.pdf( 参考系统:使用XPS SPI访问Spartan-3AN系统内闪存)http://www.xilinx.com/products/boards/s3astarter/reference_designs.htm(Spartan-3A / 3AN FPGA入门套件电路板设计实例)见涂料 和flash程序员设计。 BT 以上来自于谷歌翻译 以下为原文 All Xilinx FPGAs are CCL (CMOS configuration latch) based - which are volatile like SRAM. Spartan-3AN is a Spartan-3A die stacked in the same package with a Flash configuration device... http://www.xilinx.com/support/documentation/user_guides/ug333.pdf (Spartan-3AN In-System Flash User Guide) http://www.xilinx.com/support/documentation/application_notes/xapp1034.pdf (Reference System: Accessing Spartan-3AN In-System Flash using XPS SPI) http://www.xilinx.com/products/boards/s3astarter/reference_designs.htm (Spartan-3A/3AN FPGA Starter Kit Board Design Examples) see the paint and flash programmer designs. bt |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2355 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
203浏览 1评论
653浏览 0评论
GMT+8, 2024-9-22 04:06 , Processed in 1.280464 second(s), Total 80, Slave 64 queries .
