嗨,
哪个用户AC6项目可以与STEVAL_IHM042V1结合使用? 我想用STEVAL_IHM042V1运行两个带霍尔传感器的电机 它是: Web Project AC6 STM32F30x_UserProject - >配置STM32303C-EVAL_DUALDRIVE? 谢谢 以上来自于谷歌翻译 以下为原文 Hi, which user AC6 project can be used in combination with STEVAL_IHM042V1? I would like to use the STEVAL_IHM042V1 to run two motors with hall sensors Is it: WebProjectAC6STM32F30x_UserProject -> config STM32303C-EVAL_DUALDRIVE? Thanks |
6个回答
嗨恩里科,
感谢您的反馈意见。 已配置Workbench项目(功率级 - >电流读取拓扑 - >一个分流电阻)作为两个电机的1个分流电阻传感器。 与霍尔传感器一起支持的两个电机是否有1个分流电阻检测? 以上来自于谷歌翻译 以下为原文 Hi Enrico, Thanks for your feedback. Workbench Project has been configured (Power Stage -> Current reading topology -> One Shunt Resistor) as 1 shunt resistor sensing for both motors. Is 1 shunt resistor sensing for both motors supported in combination with Hall sensors? |
嗨恩里科,
谢谢你的消息来源。我用你提供给我的.bin文件刷了一下电路板。不幸的是,没有结果。我无法使用您的帖子中包含的Motor Control Workbench项目连接到目标(消息:连接失败!)。我认为由于application / .bin文件,目标挂起或未正确启动。 请注意,IHM042V1使用的303CC MCU来自与303C EVAL板MCU不同的封装。 以上来自于谷歌翻译 以下为原文 Hi Enrico, Thanks for the sources. I have flashed the board with .bin file you provided to me. Unfortunately, no result. I’m not able to connect to the target using the Motor Control Workbench project which was included in your post (message: Connection failed!). I think the target hangs, or is not started properly because of the application / .bin file. Be aware that the IHM042V1 uses a 303CC MCU which is from a different package than the 303C EVAL board MCU. |
对不起格柏,但我有更多的建议,我没有董事会来测试它。
也许 Forte.Gianluigi “可以提供帮助。 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Sorry Gerber, but I have more suggestions for you and I have not the board to test it. Maybe Forte.Gianluigi ‌ could help. Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
2411 浏览 1 评论
3127 浏览 1 评论
1698 浏览 1 评论
3510 浏览 6 评论
5865 浏览 21 评论
854浏览 4评论
1229浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
495浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1211浏览 3评论
1265浏览 3评论
GMT+8, 2024-9-20 10:31 , Processed in 1.081566 second(s), Total 55, Slave 50 queries .
