你好,
我很难在主机上使用C++控制台应用程序的CyCopyDealPosik/Wrad。代码实际上来自赛普拉斯图书馆的文档。FX3固件是USPSPIDMADCOD示例代码。 我的问题是EPT & Gt;写/读函数总是返回false。我还尝试了控制中心C代码,它返回true。 我可能做错什么了吗? CyCube端点*EPT=USB设备-GT;ControlEndPt; BOL BXFEXCENTALL = FALSE; 只为打字效率 EPT-GT;目标=TGTY装置; EPQ-GT;ReqType=Reql供应商; EPT & Gt;ReqCode=0x07; EPT & gt;值=1; EPT & Gt;指数=0; 无符号CHARBUF〔512〕; 零内存(BUF,512); 长ByTestOsTe= 128; BXFEXECUTE = EPT & GT;写入(BUF,ByestOSORDEN); 谢谢, 迪克 以上来自于百度翻译 以下为原文 Hi, I am having trouble to using CCyControlEndPoint read/write for C++ console application on host. The code actually from Cypress library document. The FX3 firmware is the U***SpiDmaMode sample code. My issue is the ept->Write/Read function always return false. I also tried on Control Center C# code, it returns true. Anything I might have done wrong? CCyControlEndPoint *ept = USBDevice->ControlEndPt; bool bXferCompleted = false; // Just for typing efficiency ept->Target = TGT_DEVICE; ept->ReqType = REQ_VENDOR; ept->ReqCode = 0x07; ept->Value = 1; ept->Index = 0; unsigned char buf[512]; ZeroMemory(buf, 512); LONG bytesToSend = 128; bXferCompleted = ept->Write(buf, bytesToSend); Thanks, Dick |
没关系,我明白了。
我有调试端口USB到串行电缆连接。因此有超过1个CyPress USB设备。谢谢 以上来自于百度翻译 以下为原文 Never mind, I got it. I have debug port USB-to-Serial cable connected as well. So there are more than 1 Cypress USB devices. Thx |
762个成员聚集在这个小组
加入小组2172 浏览 1 评论
1924 浏览 1 评论
3739 浏览 1 评论
1845 浏览 6 评论
1592 浏览 1 评论
812浏览 2评论
568浏览 2评论
499浏览 2评论
462浏览 2评论
1334浏览 2评论
GMT+8, 2025-3-23 16:01 , Processed in 0.931135 second(s), Total 77, Slave 61 queries .
