扫一扫,分享给好友
您好,我购买了Vivado Designe Suite HL,浮动许可证(2017年11月)。很遗憾,我意识到Sivan 7只支持Vivado太晚了。问题是我必须使用Spartan 6(xc6slx45)和MikroBlaze。我的操作
系统是Windows 10,所以我使用Xilinx的虚拟盒解决方案。我尝试使用EDK但是我收到许可证错误(请参阅附件)。在产品许可页面上我找不到EDK选项。很遗憾,我找不到任何解决方案 帮助文档。我怀疑我在许可证生成过程中做错了。有什么解决方案吗?提前谢谢你。 BX 以上来自于谷歌翻译 以下为原文 Hello, I have purchased a Vivado Designe Suite HL, Floating License (November 2017). Regrettably I realized too late that only Spartan 7 is supported with Vivado. The problem is I have to work with Spartan 6 (xc6slx45) and MikroBlaze. My operating system is Windows 10, so I use the virtual box solution from Xilinx. I try to use EDK but I get a license error (see attachments). On the product Licensing page I cannot find EDK option. Unfortunately I could not find any solution in the help documents. I suspect that I did something wrong with the license generation process. Is there any solution ? Thank you in advance. BX |
5个回答
你好@ aporiabx,
由于您购买了Vivado Design Suite System Edition许可证,这意味着您可以免费获得等效的“ISE System Edition许可证”(这就是目前ISE许可证的提供方式)。 因此,请登录www.xilinx.com/getlicenses,在“创建新许可证”表下,您应该可以看到您的“浮动系统版许可证”。 请为您当前的Vivado System Edition浮动许可证文件生成相同的主机ID和主机(服务器)名称,然后生成后,将此许可证提供给您的浮动许可证管理员,他们可以合并此“ISE系统版本” 使用您当前的Vivado浮动许可证获得许可证,然后,您将能够克服此缺失的XPS许可证问题,因为ISE System Edition许可证包含您需要的XPS许可证功能。 如果您有任何其他问题,请告诉我。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @aporiabx, As you have purchased a Vivado Design Suite System Edition license, this means that you were automatically given an equivalent 'ISE System Edition license' for free (this is how ISE licenses are provided these days). Therefore, please log in to www.xilinx.com/getlicenses and under Create New Licenses table, here you should be able to see your floating 'ISE System Edition license'. Please generate this for the same Host ID and Host (Server) name as your current Vivado System Edition floating license file and then, once generated, provide this license to your floating license admin, who'd be able to merge this 'ISE System Edition license' with your current Vivado floating license and that is it then, you'll be able to overcome this missing XPS license issue then, as ISE System Edition license contains XPS licensing feature that you need. If you have any further questions, please let me know. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
Xilinx网站很难找到购买ISE EDK软件包的官方方法......但根据这篇文章:
https://forums.xilinx.com/t5/Embedded-Development-Tools/Differences-between-SDK-EDK-and-XPS/m-p/745594/highlight/true#M41048 如果您购买Vivado系统版,您还可以获得ISE EDK的许可。 您可能必须从Vivado Design Suite升级到Vivado System Edition。 您应该联系您购买Vivado的经销商,并获得升级报价。 不要忘记通过接受帖子作为解决方案来尽可能地关闭线程。 以上来自于谷歌翻译 以下为原文 The Xilinx website makes it very hard to find any official method to purchase the ISE EDK package... but according to this post: https://forums.xilinx.com/t5/Embedded-Development-Tools/Differences-between-SDK-EDK-and-XPS/m-p/745594/highlight/true#M41048 If you buy a Vivado System Edition, you also get a license for ISE EDK. you may have to upgrade from Vivado Design Suite to Vivado System Edition. You should contact your distributor where you purchased Vivado, and get a quote on upgrading. Don't forget to close a thread when possible by accepting a post as a solution. |
你好@ aporiabx,
由于您购买了Vivado Design Suite System Edition许可证,这意味着您可以免费获得等效的“ISE System Edition许可证”(这就是目前ISE许可证的提供方式)。 因此,请登录www.xilinx.com/getlicenses,在“创建新许可证”表下,您应该可以看到您的“浮动系统版许可证”。 请为您当前的Vivado System Edition浮动许可证文件生成相同的主机ID和主机(服务器)名称,然后生成后,将此许可证提供给您的浮动许可证管理员,他们可以合并此“ISE系统版本” 使用您当前的Vivado浮动许可证获得许可证,然后,您将能够克服此缺失的XPS许可证问题,因为ISE System Edition许可证包含您需要的XPS许可证功能。 如果您有任何其他问题,请告诉我。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @aporiabx, As you have purchased a Vivado Design Suite System Edition license, this means that you were automatically given an equivalent 'ISE System Edition license' for free (this is how ISE licenses are provided these days). Therefore, please log in to www.xilinx.com/getlicenses and under Create New Licenses table, here you should be able to see your floating 'ISE System Edition license'. Please generate this for the same Host ID and Host (Server) name as your current Vivado System Edition floating license file and then, once generated, provide this license to your floating license admin, who'd be able to merge this 'ISE System Edition license' with your current Vivado floating license and that is it then, you'll be able to overcome this missing XPS license issue then, as ISE System Edition license contains XPS licensing feature that you need. If you have any further questions, please let me know. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好@aporiabx,
这个主题仍然是开放的,等着你。 如果您的问题已得到解答和/或您的问题已得到解决,请将已解决的问题标记为已接受的解决方案(有关详细信息,请访问此处:https://forums.xilinx.com/t5/help/faqpage/faq-category -id /解决方案#)。 这样,主题即可完成。 如果没有解决/回答,请回复主题。 提前谢谢,祝你有个美好的一天。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @aporiabx, This topic is still open and is waiting for you. If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then. If this is not solved/answered, please reply in the thread. Thanks in advance and have a great day. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
请原谅迟到的回复,我正在度假。
请原谅迟到的回复,我正在度假。我刚刚解决了许可证问题。 非常感谢您的支持。 亲切的问候 BX 以上来自于谷歌翻译 以下为原文 Please excuse the late reply, I was on vacation. Please excuse the late reply, I was on vacation. and I've just solved the license problem. Thank you very much for your support. Kind Regards BX |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1179浏览 1评论
587浏览 1评论
451浏览 1评论
2005浏览 0评论
731浏览 0评论
GMT+8, 2024-12-23 23:42 , Processed in 1.370890 second(s), Total 54, Slave 48 queries .
