我想使用matlab(安装在PC上)控制GPIB将大约48000点的ARB波形加载到33250.我已经检查了33250的内存大小可以支持超过64000点。
我能够将24点数据下载到信号源。 有用。 但超过24分,如48分,就会出现错误。 并且33250的输出将更改为EXP_RISE信号。 然后我尝试发送命令'APPLY:USER VOLAtiLE'。 它不起作用。 有人知道如何将数据加载到33250吗? 非常感谢。 以上来自于谷歌翻译 以下为原文 I want to use Matlab (installed on PC ) to control GPIB to load an ARB waveform with about 48000 points into 33250. I already checked the memory size of 33250 can support over 64000 points. I was able to download a data with 24 points to the signal gen. It works. But over 24 points, like 48 points, there would be an error. And the output of 33250 will be changed to EXP_RISE signal. Then I tried to send the command 'APPLY:USER VOLATILE'. It did not work. Does anybody know how to load a data to 33250? Thanks a lot. |
看一下这个例子:http://www.mathworks.com/matlabcentral/fileexchange/38389
以上来自于谷歌翻译 以下为原文 Take a look at this example: http://www.mathworks.com/matlabcentral/fileexchange/38389 |
1030 浏览 0 评论
2276 浏览 1 评论
2063 浏览 1 评论
1933 浏览 5 评论
2806 浏览 3 评论
797浏览 1评论
583浏览 0评论
676浏览 0评论
2462浏览 0评论
1519浏览 0评论
GMT+8, 2024-9-20 13:57 , Processed in 1.224396 second(s), Total 43, Slave 38 queries .
