扫一扫,分享给好友
你好,
我最近安装了PSoC创建者4.1,并在启动时看到错误: PSoC Creator的一个重要部分有问题,可能无法正常工作。请重新启动PSoC Creator。 当初始化下列错误时,出现此错误: CyDeRel.Un.D.DeICeD.B.Calcord.CydCpLuin CyDr.CyrMgM.CyPRJMGR CyDeRel.U.B.Cys3dB.Cys3Db工厂 Cydiel.DeC.C.F. Cydiel.DeVIC.FiTff.CyFiTffMpLuin 另外,当关闭PSoC Creator时,我得到这个错误(和其他类似的错误): 这个产品在你的电脑上有问题。威廉希尔官方网站 错误原因:当试图完全关闭插件FM钳工时抛出一个异常:A7614A5F1764EC2-B0098356A8F3DC8'。异常消息:对象引用未设置为对象实例。 我尝试过多次重新安装,以及卸载其他PSoC软件包。我在本周早些时候在没有这些问题的3。x系列中有一个PSoC Creator版本,所以我不知道如何解决这个问题。有人有什么建议吗? 我使用MaOS102.6(SieRa)的并行13和Windows 10。 谢谢! 乔伊 以上来自于百度翻译 以下为原文 Hi, I recently installed PSoC Creator 4.1 and see errors on startup: An important piece of PSoC Creator has a problem and may not work correctly. Please restart PSoC Creator.This error shows up when the following are being initialized: CyDesigner.Common.Db.DeviceDb.Catalog.CyDcPluginAdditionally, when closing PSoC Creator, I get this error (and others which are similar): This product had trouble launching on your computer. Technical error reason: An exception was thrown when trying to fully close plugin 'FM Fitter:a7614a5f-f176-4ec2-b000-98356a8f3dc8'. Exception Message: Object reference not set to an instance of an object..I've tried to do a fresh reinstall several times, as well as uninstalling other PSoC packages. I had a version of PSoC Creator in the 3.X series working earlier in the week without these issues, so I'm not sure how to fix this. Does anyone have any suggestions? I'm using macOS 10.12.6 (Sierra) with Parallels 13 and Windows 10. Thanks! Joey |
苹果和Linux操作系统支持PSoC®软件和工具包KBA875
以上来自于百度翻译 以下为原文 Apple and Linux OS Support for PSoC® Software and Kits - KBA87545 |
谢谢你的链接。这促使我仔细检查发布说明,因为我记得至少有一些其他的平台阅读,发现线: Mac OS X的El Capitan在Parallels Desktop 11运行Windows 10 我不能做太多自己的MacOS版本,但我认为它可能是值得一试的降级的相似之处。乍一看,它看起来像是在与Parallels 11和Windows 10 Sierra。但我猜如果我遇到问题,我就不走运了… 谢谢! 乔伊 以上来自于百度翻译 以下为原文 Thanks for the link. This prompted me to double check the release notes since I had remembered reading at least a few other supported platforms, and found the line: Mac OS X El Capitan on Parallels Desktop 11 running Windows 10I can't do much about my macOS version, but I thought it might be worth trying to downgrade Parallels. At first glance it looks like it's working in Sierra with Parallels 11 and Windows 10. But I guess if I do run into issues, I'm out of luck... Thanks! Joey |
762个成员聚集在这个小组
加入小组2171 浏览 1 评论
1923 浏览 1 评论
3737 浏览 1 评论
1844 浏览 6 评论
1591 浏览 1 评论
811浏览 2评论
567浏览 2评论
498浏览 2评论
459浏览 2评论
1332浏览 2评论
GMT+8, 2025-3-20 06:06 , Processed in 0.775886 second(s), Total 46, Slave 41 queries .
