扫一扫,分享给好友
你好
我有一个带有许可证表的新ZC706评估板。 我还有2个额外的ZC706评估板,其中缺少许可证。 我可以生成一个.lic文件(在许可证站点上显示许可证类型=节点)并将其复制到多台计算机上以运行多个Vivado会话并在所有3个ZC706评估板上工作吗? 谢谢 以上来自于谷歌翻译 以下为原文 Hi I have one new ZC706 Evaluation Board with a license sheet. I have 2 additional ZC706 Evaluation boards where the license sheet is missing. Can I generate one .lic file (on the license site it says License Type=Node) and copy it on multiple computers to run multiple Vivado sessions and work on all 3 ZC706 Evaluation boards? Thanks |
9个回答
你好@ arasch,
实际上,如果您购买了3个ZC706评估板,那么在所有这3个评估板中,您应该已经收到了可以兑换的许可凭证。 在这种情况下,您应该收到3个节点锁定的设备锁定许可证。 如果您发现这3个套件中有2个您只收到1个凭证而不是3个凭证,那么在这种情况下,请联系您购买这些套件的Disti FAE,并向他们表明您遗失了 您收到的3个套件中有2个有2张许可证。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @arasch, Indeed, if you've purchased 3 ZC706 Evaluation Boards, in all 3 of these you should have received a licensing voucher that you can redeem. In this case, you should receive 3 Node-Locked Device Locked licenses. If you see an issue where in 2 out of these 3 kits you've only received 1 voucher and not 3, then in this case, please contact the Disti FAE who you've purchased these kits from and indicate to them that you are missing 2 license vouchers in 2 out of 3 kits you've received. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
嗨@ arasch,
节点锁定许可证适用于单个计算机的主机ID。 您将无法在多台计算机上使用它。 虽然单机上允许多个同时用户。 您需要浮动许可证才能满足您的要求。 Reagards, hemangd 以上来自于谷歌翻译 以下为原文 Hi @arasch, Node locked license works for single computer's host ID. You will not able to use it with multiple computers. Though multiple simultaneous users allowed on single machine. You will need floating license for your requirement. Reagards, hemangd |
嗨@hemangd
谢谢回复。 如何获得ZC706评估套件的浮动许可证? 我希望能够在多台计算机上工作,并且当代码准备好插入电路板进行测试时。 另外,如何使用缺少许可证表的其他两个ZC706评估套件? 谢谢 以上来自于谷歌翻译 以下为原文 Hi @hemangd Thanks for the reply. How do I get a floating license for the ZC706 Evaluation Kit? I would like to be able to work on multiple computers and when code is ready plug in the board for testing. Also, how can I use the other two ZC706 Evaluation Kits where the License sheet is missing? Thanks |
嗨@ arasch,
>>我还有2个额外的ZC706评估板,其中缺少许可证。 您应该联系Xilinx FAE获取此遗失的许可证。 他/她可以帮助你。 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @arasch, >> I have 2 additional ZC706 Evaluation boards where the license sheet is missing. You should contact your Xilinx FAE for this missing licenses. He/She may help you out on it. Regards, hemangd |
你好@ arasch,
实际上,如果您购买了3个ZC706评估板,那么在所有这3个评估板中,您应该已经收到了可以兑换的许可凭证。 在这种情况下,您应该收到3个节点锁定的设备锁定许可证。 如果您发现这3个套件中有2个您只收到1个凭证而不是3个凭证,那么在这种情况下,请联系您购买这些套件的Disti FAE,并向他们表明您遗失了 您收到的3个套件中有2个有2张许可证。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @arasch, Indeed, if you've purchased 3 ZC706 Evaluation Boards, in all 3 of these you should have received a licensing voucher that you can redeem. In this case, you should receive 3 Node-Locked Device Locked licenses. If you see an issue where in 2 out of these 3 kits you've only received 1 voucher and not 3, then in this case, please contact the Disti FAE who you've purchased these kits from and indicate to them that you are missing 2 license vouchers in 2 out of 3 kits you've received. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
您好@anatoli和@hemangd
谢谢你的电子邮件。 是的我有一个ZC706评估套件的许可凭证,并在我们的一台计算机上兑换。 但是,我想在另外2台计算机上安装和设置Vivado,这样员工就可以使用它们并为一个ZC706评估套件设计软件/硬件(我将联系FAE获取其他两个ZC评估套件的许可)。 我是否需要浮动许可证(我需要联系FAE)或者我使用许可证凭证生成的一个许可证文件是否足以在3台计算机上工作(3个Vivado会话)? 谢谢 以上来自于谷歌翻译 以下为原文 Hi @anatoli and @hemangd Thanks for your emails. Yes I have one licensing voucher for one of the ZC706 Evaluation Kits and redeemed it on one of our computers. However I would like to install and setup Vivado on 2 more computers so employees can work also on them and design software/hardware for the one ZC706 Evaluation Kit (I will contact FAE for the other two ZC Evaluation Kits for licensing). Will I need a floating license (for which I would need to contact the FAE) or does the one license file I generated with the license voucher suffice to work on 3 computers (3 Vivado sessions)? Thanks |
您好@anatoli和@hemangd
谢谢你的帮助。 根据一个ZC706评估套件的一个许可证凭证,在3台计算机上安装节点锁定许可证是没有问题的。 我只需为每台计算机生成自己的Vivado.lic许可文件,该文件将发送到Xilinx产品许可网站。 要生成节点许可证,我必须: 1.从Vivado License Manager读取 - >查看主机信息,“主机名”和“网络接口卡(NIC)ID”之一(始终是第一个...) 2.在Xilinx许可网站的相应字段中写下这些值(如果其他人卡在此处,请参阅随附的屏幕截图) 3.获取发送到您的电子邮件帐户的许可证并将其加载到Vivado许可证管理器中 但是对于缺少许可证凭证的其他两个董事会,我想我将不得不联系FAE。 谢谢 以上来自于谷歌翻译 以下为原文 Hi @anatoli and @hemangd Thanks for your help. It was no problem to install Node locked licenses on 3 computers based on the one license voucher of the one ZC706 Evaluation Kit. I just had to generate for each computer its own Vivado.lic license file going to the Xilinx Product licensing website. To generate the Node licenses I had to: 1.read from the Vivado License Manager -> View Host Information, the "Host Name" and one of the "Network Interface Card (NIC) ID" (taking always the first...) 2. write those values in the respective fields on the Xilinx Licensing website (see attached screen-shot in case someone else gets stuck here) 3. Get the license sent to your email account and load it into the Vivado License Manager However for the two other boards where the license voucher is missing I guess I will have to contact the FAE. Thanks |
嗯,不。我尝试了两个ZC706板中的一个,我没有许可证凭证,并且可以编程也没有任何问题。
我有点困惑,但对我有用...... 谢谢 以上来自于谷歌翻译 以下为原文 Hmm, No. I tried one of the two ZC706 boards where I don't have the license voucher and that one can be programmed without any problems as well. I'm a little confused but works for me ... Thanks |
你好@ arasch,
根据您共享的屏幕截图,看起来您已经生成了Vivado 30天评估许可证,这是一个完整许可证,具有此许可证设置的30天到期限制(即30天后此许可证将过期, 然后你就开始收到许可错误了。 无论如何,ZC706包括XC7Z045和XC7Z045设备不是webpack相关设备,你需要一个完整的许可证或一个设备锁定许可证,应该是你的(每个)购买的套件免费提供给你。 因此,请联系DFAE并要求他们向您发送其他2ZC706板的套件优惠券中的2个丢失,因为您将无法在3台不同的PC上使用单个设备锁定的节点锁定许可证,每个PC都针对一块板。 但是,如果计划在单个/同一台计算机上使用所有这3个套件,则在这种情况下,一个节点锁定许可证就可以了。 希望以上是清楚的。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @arasch, Based on the screenshot you've shared, looks like you've generated Vivado 30-days evaluation license, which is a full license with the limitation of the 30-day expiration set on this license (i.e. after 30 days this licence will get expired and you'd then start receiving licensing errors then). Anyhow, ZC706 includes the XC7Z045 and XC7Z045 device is not a webpack related device and you'd need either a full license for this or a device locked license that supposed to come to you for free with your (each) purchased kit. Therefore, please contact DFAE and request them to send you your 2 missing in the kit vouchers for your other 2 ZC706 boards, as you will not be able to use a single Device locked Node-Locked license on 3 different PCs, each targeting a board.. However, if all these 3 kits are planned to be used on a single/same machine, then one node-locked license is OK in this case. Hope the above is clear. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2694 浏览 7 评论
3013 浏览 4 评论
2433 浏览 9 评论
3539 浏览 0 评论
2636 浏览 15 评论
3422浏览 1评论
835浏览 1评论
697浏览 1评论
GMT+8, 2025-7-6 09:11 , Processed in 1.474350 second(s), Total 92, Slave 76 queries .
