我确实遇到了一个我想解决的问题。
这更像是Vivado的实现问题。 我正在尝试使用ILA内核和探针将调试内核添加到我的设计中。 执行设计后,我收到以下错误: [Chipscope 16-119]实现调试核心dbg_hub失败。 错误:[Chipscope 16-111] Vivado Analyzer功能的许可证检查失败 - 中止调试核心实施。 许可证文件显示“到期日期”是永久性的,但“版本限制”是2016.05。 我附上了“环境报告”,其中显示分析仪和Chipscope的版本超出了版本限制范围。 考虑到我们有永久许可,我该如何解决这个问题? 环境报告.docx 37 KB CDebug Error.docx 161 KB 以上来自于谷歌翻译 以下为原文 I do have an issue that I am trying to resolve. This is more of an implementation issue with Vivado. I am attempting to add debug cores to my design with ILA cores and probes. Upon implementation of the design I received the following error: [Chipscope 16-119] Implementing debug core dbg_hub failed. ERROR: [Chipscope 16-111] License check failed for Vivado Analyzer Feature - aborting debug core implementation. The license file shows that the "Expiration Date" is permanent, though the "Version Limit" is 2016.05. I have attached the "environmental report" also that shows the version of the Analyzer and Chipscope are outside the version limit range. How can I resolve this issue, considering we have a permanent license? environment report.docx 37 KB CDebug Error.docx 161 KB |
4个回答
嗨@vharpernpa,
我很欣赏日志文件。 你在运行什么版本的工具? 如果您运行的时间晚于Vivado 2016.1,则许可证将不兼容,并且不支持分析仪功能。 https://www.xilinx.com/support/answers/33770.html 谢谢, 德文 - 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @vharpernpa, I appreciate the log files. What version of the tools are you running? If you are running anything later than Vivado 2016.1 then the license will not be compatible and not support the analyzer feature. https://www.xilinx.com/support/answers/33770.html Thank you, Devin View solution in original post |
嗨@vharpernpa,
我很欣赏日志文件。 你在运行什么版本的工具? 如果您运行的时间晚于Vivado 2016.1,则许可证将不兼容,并且不支持分析仪功能。 https://www.xilinx.com/support/answers/33770.html 谢谢, 德文 - 以上来自于谷歌翻译 以下为原文 Hi @vharpernpa, I appreciate the log files. What version of the tools are you running? If you are running anything later than Vivado 2016.1 then the license will not be compatible and not support the analyzer feature. https://www.xilinx.com/support/answers/33770.html Thank you, Devin |
谢谢回复。
15.2中的工具版本。 我去了另一台笔记本电脑并复制了许可证文件,这似乎解决了这个问题。 我非常感谢你在此事上的时间和考虑。 以上来自于谷歌翻译 以下为原文 Thanks for the reply. The version of the tool in 15.2. I went to another laptop and copied the license file over, and that seems to have resolved the issue. I really appreciate your time and consideration on this matter. |
你好@vharpernpa,
非常感谢让我们知道,我们很高兴看到您的问题现在得到解决。 在您的问题得到解决后,请将适当的回复标记为已接受的解决方案(有关详细信息,请访问此处:https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions) ,那么话题就可以完成了。 感谢您的帮助。 提前谢谢,祝你有个美好的一天。 亲切的问候,Anatoli Curran,Xilinx威廉希尔官方网站 支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @vharpernpa, Thanks a lot for letting us know and we are glad to see your issue is resolved now. As your issue is solved, please mark an appropriate response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so the topic can be completed then. We appreciate your help. Thanks in advance and have a great day. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2453浏览 1评论
660浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 15:31 , Processed in 1.913334 second(s), Total 83, Slave 67 queries .
