我刚刚安装了一个新的系统并安装了MPLAB XIDE 4.01,我的真正的ICE并没有显示在一个项目上作为调试选项。PkIIT 3是显示调试选项的唯一项目。真正的ICE显示在MPLAB IPE中作为一个选项。这个系统从来没有任何其他版本的MPLAB。我尝试过UNIN。暂停司机和更新驱动程序。我已经卸载/重新安装程序没有成功。有没有其他人遇到这个问题,它是如何固定?
以上来自于百度翻译 以下为原文 I just setup a new system and installed MPLAB XIDE 4.01 and my Real ICE does not show up as a debug option on a project. PICKIT 3 is the only item showing as a debug option. The Real ICE shows up in MPLAB IPE as an option. This system has never had any other version of MPLAB on it. I have tried to uninstall the driver and update the driver. I have uninstalled / reinstalled the program several times without success. Has anybody else run into this and how did it get fixed? |
4个回答
我注意到,有时MPLAB X 4.01花了一些时间来识别我重新插入真正的冰解封后,以解决一个端点故障。我想知道当USB问题发生时Windows是否帮助我。我发现有时需要重新启动。它可能清除缓存已经工作。其他时间足够等待几分钟,重新插入真正的冰,它再次工作。
以上来自于百度翻译 以下为原文 I have noticed on occasion Mplab X 4.01 has taken some time to recognize my re inserting the Real ICE after unplugging to resolve an endpoint failure. I am wondering if Windows is helping me out when a USB problem happens. I have found it sometimes necessary to reboot. It may be clearing the cache would have worked. Other times it is sufficient to wait a few minutes and re insert the Real ICE and it works again. |
我也找到了一样的东西。有时,ICD3或Realice在我重启或等待之前就不起作用,它们在我连接的时候突然开始工作。所以基本上,它们工作时“每当他们感觉到它”。
以上来自于百度翻译 以下为原文 I've found the same. Sometimes an ICD3 or RealICE will just not work until I reboot or just wait it out and they suddenly start working next time I connect. So basically they work "Whenever they feel like it". |
嗯,我要试着把机器上的所有芯片都擦掉,包括注册表项,看看是否能让它正常工作。
以上来自于百度翻译 以下为原文 Hmm. I'm going to try wiping everything Microchip off the machine including registry entries and see if I can get it working. |
5244 浏览 9 评论
2035 浏览 8 评论
1955 浏览 10 评论
3209 浏览 3 评论
2260 浏览 5 评论
779浏览 1评论
672浏览 1评论
598浏览 1评论
682浏览 0评论
579浏览 0评论
GMT+8, 2024-12-25 10:38 , Processed in 1.282877 second(s), Total 51, Slave 46 queries .
